how hard is it to put a lift....
Discussion in '100-Series Cruisers' started by Liam, Aug 16, 2006.
  1. Liam
    Liam
    4,548
    Media:
    31
    Albums:
    4
    13
    Feb 10, 2005
    in the nappy dugout
    ....in my 100? I am thinking about getting the OME 2inch lift and wondered if this is something i could put in myself.......and yes, i am somewhat mechanicaly inclined.....and challenged...:flipoff2:
    What is the benifit to go with OME heavies instead of OME regular? What is the benifit to put in the Diff drop that Slee sells??
    help a brotha out here....
  2. spressomon
    spressomon glutton Moderator
    12,559
    Media:
    13
    Albums:
    1
    1,163
    Jan 9, 2005
    Northern Nevada
    The front and rear shocks along with the rear springs were a :banana: :banana: job...and would be a :banana: job if not for the upper rear shock mounts that are a total PITA! My OEM t-bars were so corroded in place I had to take my 100 in to a shop to have them removed and the OME installed...if your 100/LX has any corrosion whatsoever the t-bars are going to be a challenge without lots of repeated sessions of flame and PB. Oh yeah...be sure to PB (PB Blaster) all the bolts/nuts repeatedly (as usual anyway) several days in advance of installing your parts. Be sure to get a quality alignment done after your complete install.
    Definitely go with the Slee Diff Drop kit...it will help keep the CV shaft angle closer to stock. Having said that, based upon most of us here, keep an eye on your CV boots for leakage post lift install and be ready to remove the offending band clamp and reclamp: Otherwise replacement of the CV axle will be necessary!
    Don't know about the "heavies".
  3. macneill
    macneill Rollin’ on 33s
    4,062
    9
    Jun 2, 2004
    Port Washington, NY / Edgartown, MA
    Mine was really simple to install. I dropped the truck off at OK4WD, went for a hike around Merrill Reservoir, had some lunch, took a nap, then returned at the end of the day and voila, it was installed. :hillbilly:
    I'd go with the OME T-Bars too to get the front end up.
  4. spressomon
    12,559
    Media:
    13
    Albums:
    1
    1,163
    Jan 9, 2005
    Northern Nevada
    Good job Mac...that's a 1/2:banana: job since you actually had to hike:D
  5. Liam
    Liam
    4,548
    Media:
    31
    Albums:
    4
    13
    Feb 10, 2005
    in the nappy dugout
    maybe i should have put in that i dont have Mac money to spend......:grinpimp:
    do the OME T-Bars come with the Slee package??
  6. spressomon
    12,559
    Media:
    13
    Albums:
    1
    1,163
    Jan 9, 2005
    Northern Nevada
    No...you need to order them separately. IMO if you are going to run the stock bumper then you can probably get by OK with the stock t-bars.
  7. Liam
    Liam
    4,548
    Media:
    31
    Albums:
    4
    13
    Feb 10, 2005
    in the nappy dugout
    i am thinking about going with a ARB..........
  8. beaufort-fj60
    beaufort-fj60
    4,511
    Media:
    10
    Albums:
    1
    11
    Feb 5, 2005
    go visit Dearborn.... junk is a pickle pusher:flipoff2:
  9. spressomon
    12,559
    Media:
    13
    Albums:
    1
    1,163
    Jan 9, 2005
    Northern Nevada
    Then get the OME T-bars and do it all at the same time.
  10. Liam
    Liam
    4,548
    Media:
    31
    Albums:
    4
    13
    Feb 10, 2005
    in the nappy dugout
    That may be the way to go...David did say he would trade LC work for steaks.....
  11. bull
    bull
    3,204
    Media:
    11
    Albums:
    3
    6
    Feb 7, 2002
    Pendleton Oregon
  12. 1HUNJY
    1HUNJY
    7
    Aug 17, 2006
    Perth,Australia
    If your changing the Torsions fit the Lower control arm Reinforcing Brackets...
  13. yooper
    yooper SILVER Star
    4,132
    Media:
    6
    Albums:
    1
    284
    Sep 17, 2002
    Da Yoop
  14. spressomon
    12,559
    Media:
    13
    Albums:
    1
    1,163
    Jan 9, 2005
    Northern Nevada
  15. yooper
    yooper SILVER Star
    4,132
    Media:
    6
    Albums:
    1
    284
    Sep 17, 2002
    Da Yoop
    Available in the USA?
  16. spressomon
    12,559
    Media:
    13
    Albums:
    1
    1,163
    Jan 9, 2005
    Northern Nevada
    Not to my knowledge. And I have not heard of anyone stateside cracking their lower A-arms...only the Aussies.
  17. 1HUNJY
    1HUNJY
    7
    Aug 17, 2006
    Perth,Australia
    Damm aussies...;) ..We do have a problem with them here in aussie,infact there was a recall for them to check the weld length on the lower arm.ARB have a lower control arm reinforcing kit (FK27) which when i had the OME kit fitted to mine i had torsions replaced and while they were out i had kit fitted...
  18. macneill
    4,062
    9
    Jun 2, 2004
    My biggest obstacle is space. Living in Manhattan doesn't allow me for any sort of area to wrench. Course I could just do it Brooklyn Style and do it on the street. However, I did manage to install my own sliders...
  19. Liam
    Liam
    4,548
    Media:
    31
    Albums:
    4
    13
    Feb 10, 2005
    in the nappy dugout
    yeah, window sliders in your condo:rolleyes: :D
  20. macneill
    4,062
    9
    Jun 2, 2004
    It's a co-op bizaatch! :flipoff2:
