Gears baby, GEARS!!!
I think the formula for power loss is 3.5% (not sure) per 1,000' of elev gain so it's a hefty loss when you don't have any spare ponies!
That is very close based on "standard" atmospheric conditions... the actual losses will vary from day to day. High ambient temps will cause lower than normal air density and even less power. Combined with high altitude those losses can be significant and the reason pilots use "density altitude" to make performance calculations.
....4:88s with 285s allows you to get your 1fz up to 80mph at 15k feet....
Only if you started out at 16k feet.
Gearing is no solution for power loss at altitude. Gearing can move engine RPM in a more suitable power band for a given speed but cannot magically "create" power.
I have run the following combinations:
285s w/4:11, 285s w/4:88 and 315s w/4:88. I know for a fact that a naturally aspirated 1FZ engine cannot produce enough power to run 3rd or 4th gear pulling 6000+ lbs while climbing a steep grade over 9000'.
I have made many trips with various loads and/or towing an 1200' popup trailer over 11,000' passes. In every case I was forced to run in 2nd gear. If you change gears THE ONLY DIFFERENCE IS THE SPEED WHICH CAN BE DRIVEN AT A GIVEN RPM. If you go to lower gears you will go a slower speed at the same RPM.
In my case it was 6-7 mph slower at 3500 rpm going from 4:11 to 4:88 on 285s and going to 315s got me back 3-4 mph of that (still slower than 4:11s). So if it was all about speed at altitude I would stay w/ 4:11 and spin the engine at the same rpm.
I have no issue running my truck at 3800 rpm in 2nd on steep climbs and that allows me to keep up with traffic.
Don't get me wrong I think gearing should be done on these heavy trucks anytime you go with a bigger tire but it just doesn't make up for
lost HP due to altitude.
