How do I remove this bushing...
jackbrad
15 Year 10 Year
Charlotte, NC
Website
www.mattison-consulting.com
Is the only way with one of this funny pullers?
I need to put a piece of the sst tool in the spindle but, this bushing is in the way.
I have to put this tool in there there. (Red)
If I take this out will I have to buy a new one?
Are they available?
Knuckles= BIG PITA
on the spindle you only use the center part of the sst.
On the axle housing is where you will use the "spacer",of course you'll have to remove the inner axle seal...
hope this helps.
Pin_Head said:
My understanding is that you don't remove the bushing. the part you have highlighted in red IS the bushing.
I agree but, the sst tool piece will not fit in that bushing.
All I knwo to do is take it out and put it back in.
Something seems a little fishy though.
i think that if you removed it you would need a new one, and they are not sold seperatly form the spindle (at least not from toyota) this would indicate to me that toyota dose not want it taken out
90999-70067 Your disc brake spindle bushing....
Pull the sleeve off and it drops right in, provided your bushing is not nicked or damaged at all... ;)
Oh, and one of the box the tool came in...
:beer:
Thanks Steve... It did come with one sleeve however, even with it off it does not want to drop down in there. I am worried the sleeve is screwed up.... or is different than the one you showed... (Although, I bet your right somehow)
In the pic I posted and when working with it, it looks as if it is really close to dropping in... close but, no cigar.
It does not seem right to have to pull the bushing but it also seems like it will not fit. (The pic you posted kills me I wish mine could just do that.)
It I do take it out then I would have to use the sleeve in place of the bushing. Does not seem right...
I think that I have something confused. I have not tried the right spindle because I did not want to take the right apart until I had gotten done with the left.
Just the slightest nick in the bushing will create problems....
See if you can find where it it hitting and lightly dress that area with a file if it is not smooth....
I have seen some pretty wasted bushings because of broken fing birfs over the years....that one does not look to be that bad, but look at it closely, there has to be something distorted about it not letting that piece drop into the bushing....
Do you have another spindle? Does it fit in that bushing?
Do you have a dial-caliper? Can you measuer the diameter of the piece that is supposed to drop into the bushing?
update...
I took these pics... I think that they tell a lot.
It appears I have the same tool.
The bushing internals seem smaller that the sleeve piece insides and the piece that is surposed to slide in is a .1 bigger.
Same part number:
The two pieces... The sleeve and the line marker holder.
The sleeve positioned on top of the spindle bushing so you can see through it and see that the bushing is smaller internally.
Inside bushing mesaurement
Marking tool holder piece outside measurements.
Comments welcome...
All I know to do is try the other side and make sure it is the same problem. :(
Drum axle will require a different tool piece to center on the smaller diameter bushing in the drum brake spindle.
If you know a good machinist I am sure that they could make something in pretty short order for you.
I would be very surprised to find that the drum version of this tool is still available.
:beer:
