I searched but couldn't find a good thread on it. I'm a relative novice at pm other than oil changes. Never changed the dif oil. What weight should I use? I think I have some 80w-90 high performance gear oil in my parents garage. Would that work? Any suggestions would be greatly appreciated. I'm planning on doing this over the weekend.
It's easy if your plugs come out. If not... it can be really hard. Take it from a guy who didn't check the plugs first and wound up having to weld a nut to the fill plug to get it out.
Definitely get the gaskets. I'd also get new allen head plugs. The part numbers are floating around in various threads.
Simple....drain, replace gaskets, replace fluid (this is the boring part, trying to get the fluid in as quick as possible...takes longer than you would imagine), tighten up and go.
I used Amsoil 75-90 in all three. But there are many other good gear oils out there.
Simple....drain, replace gaskets, replace fluid (this is the boring part, trying to get the fluid in as quick as possible...takes longer than you would imagine), tighten up and go. I used Amsoil 75-90 in all three. But there are many other good gear oils out there.
Use any GL5 gear oil. 80W-90 is the viscosity specified by Toyota. All name brand or store brand gear oils will give good service. If you use the expensive stuff, you still need to be willing to drain it if you go into any significant water. I've opted for a yearly change of the cheap stuff, or if I've done any significant water crossing.
Buying gear oil in 5 gallon pails and using a pump makes this job much less of a chore.
Always use a new crush gasket, especially under the fill plug.
Problem with that is that with shipping I might as well order up some stuff to make it worth the while. Pretty soon the bill is up in the hundreds. I guess that's not a problem. Sometimes I feel like I should call 1-800-cruiser-help for this addiction.lol.
Use any GL5 gear oil. 80W-90 is the viscosity specified by Toyota. All name brand or store brand gear oils will give good service. If you use the expensive stuff, you still need to be willing to drain it if you go into any significant water. I've opted for a yearly change of the cheap stuff, or if I've done any significant water crossing. Buying gear oil in 5 gallon pails and using a pump makes this job much less of a chore. Always use a new crush gasket, especially under the fill plug. As stated, ALWAYS remove the fill plug first.
Agreed for small stuff. You really only need four crush washers for the two fill and two drain plugs.
Second what Cruiserdrew said about a pump. Picked up an inexpensive one at Pep Boys and then the gallon jugs the pump screws onto. Much easier than the smaller squeeze jugs.
