How difficult is changing the differential fluid?
This. If you cannot open the fill plug don't drain it or you'll end up towing your car to a shop. You will need a way to get gear oil into the fill hole. Either pump or squeeze bottle. Get some new gaskets from the Toyota dealer before you begin. Get a 24mm 6pt socket.
Recommend taking the advice above regarding the 6pt 24mm socket.
I also sprayed some PB blaster on it before attempting to loosen it up.....don't wanna strip the plugs.
If they're tight you can hammer on them to loosen things up. Pretend you're driving a nail into the diff housing. A few good whacks will slightly crush the gasket a smidgen and allow the plug to spin right out.
Not sure if it has been mentioned before, but grind the end of your socket until it is a perfectly straight 6 pt socket. The plugs are so thin they will get rounded off with an unmodified socket.
Ok. Saves me from stripping the plug and having a bigger issue. Right on! Some great advice.
Appreciate this, fellas! Good tips on the procedure and flattening out the end of the socket!
I just did this job last week and it was a breeze with the advice found here. I used a flattened 15/16 instead of a 24cm and the fill nut popped right off. Be careful which hand pump you buy as some have a smaller opening than the one gallon oil jugs. Also my AutoZone version broke five minutes into the job and pickup type fell in the oil jug.
Yeah, same thing happened to me. Auto zone pump squirted more oil out the seals than into the diff. The squirt bottle worked fine.
It took some pb blaster and hammering to get the plug loose but once loose it was a breeze. And the black sludge that came out was nasty. I am glad I replaced it. I also replace the plugs with the Allen type plug that is magnetic. The factory plugs are wierd and they seem to have rounded edges. Simple and easy mod I saw on YouTube.
Hey fellas, I've got one of these things - is this the kind of pump you're referring to?
Also, the parts guy at the Toy dealership was slightly confused by what his fiche told him, but looking at it with him, it seemed most likely that all 4 crush (fill and drain, front and rear) gaskets were the same and that these were them. From searching I know this part #'s valid, but are all four really the same?
Lastly, they only had three in stock. I bought 'em all, but it seemed like if I was to temporarily re-use one of these, it'd be on one of the fill plugs rather than on one of the drain plugs, you know, so I can put the new one on without draining again. But earlier in this thread Cruiserdrew mentioned to use new washers "especially under the fill plug". So, anything I'm not thinking of that'd make me wait to do this until I have the 4th washer, or can I use the old washer on a fill plug for a couple of days till the dealership gets restocked?
Peteinpeb,
My rear diff oil came out fairly nasty too. I'm running a cheap oil through there for a shorter interval to clean things up then will put it in slightly better stuff to go a bit longer personally... But maybe just a thought?
I don't know how expensive I'll eventually go on oils (and I'm not against non-cheapo oil - I run Mobile 1 in my bike and my wife's 2007 Honda Pilot), but I'm following this pattern, too, buying cheap, spec-compliant stuff to flush and dilute any leftover neglect before I decide what I'm using long-term.
When I first did mine they were to tight/old to get off by hand. I took it to a Sears auto center and had them loosen them (with air tools) and tighten back up so I could get them off. When I asked how much I owe them they said nothing. Oh and do your center differential while your at it... Same fluid and same procedure. Good luck sir.
Hopefully this helpful and not a thread-jack, all my comments...
Job complete, and I got some pics. Always most difficult the first time I figure, next time I'm thinking 45 minutes instead of 4.5hrs. Course, I'm counting the time I took driving to my FIL's shop to flatten the 24mm socket and time staring at the oil shelf at Autozone. The 34deg temps didn't speed things up either, especially manually pouring the used oil from my tiny catch pan back into the bottles. :crybaby:
Flattening the 24mm socket was straightforward on the bench grinder. Took it in bits to avoid overheating it. Flat was simpler to achieve than square, but I used a carpentry square to check it then tweaked will I was satisfied. And I'm uptight enough to chamfer the outer edge. :grinpimp: It worked as advertised on the plugs with my 24" cheater.
When I finally thought I had everything I needed, I found some architectural "ramps" near the apartment.
Plugs came out with a bit of force, nothing unreasonable. As advised in a earlier post, I removed the fill plug first. Here they are with their new crush washers - the one on the right with the bigger magnet is the drain plug.
The oil level was low in the front diff, and what came out was opaque and greenish. Not too pretty. (didn't photograph very well either)
I had the pump I posted earlier, but I saw this doohicky at Autozone that claimed to thread right onto the oil jug. Easy peasy, right? Well, not if it breaks on the third pump and sends its own dip tube down to an oily grave. I'll post a pic of that later so you can avoid it. Fortunately, my orange pump, while less convenient, actually worked, and I filled the front diff with inexpensive GPL-5 compliant 80W-90.
Buttoned the front up and moved to the rear where I was surprised when the rear diff oil flowed out much more clear. Possibly the PO had done the rear but not had time or been able to get to the front. There are multiple (more obvious) half-completed jobs on this rig, so it wouldn't entirely surprise me. I'm not sure the cleaner oil photographs much better than the goopy stuff, but here it is anyway.
Forgot to bring my torque wrench down where I was working, so I tightened down till I could feel that the washer was crushed and a 1/4 turn more, and I'll torque it before I drive to work on Monday.
Anyway, the logistics were way harder than the actual job. I'd give it :banana: - easier than changing the oil if you've got the right tools already.
Thanks again for the tips all! And hope yours goes well also, peteinpeb!
Roostabunny,
The orange pump is the one I bought after the first one broke halfway through filling the diff. It worked OK although it's a little messier. I bought eight of the crush washers just in case I want to change oil over the weekend and the dealer is closed.
Yeah, "messy but actually works" is better.
I'm with you, when I bought the three at the dealership I told them I wanted 5 more when the new ones came in, so I'll have the one I need plus a full spare set.
Those will work, as will almost any other 18mm gasket.
Can't believe they only had three in stock, these gaskets fit ALL the diff drain and fill plugs on everything from 4Runners to Rav4, highlander, old corollas and camry, to almost everything else. My local dealerships all have hundreds on hand at any given moment.
I actually only use the steel crushable gaskets on the drain plugs. For fill plugs I often use aluminum gaskets because they're (mostly) reusable. Just flip them over if you're re using them. Don't over tighten any of them or you'll be in a world of hurt when it comes time to remove.
The aluminum gaskets are the spec gasket for the fill and drain on the transfer case, or any aluminum housing like a manual trans on a pickup etc. Again, our local dealers have hundreds on hand.
For fill pumps I used to just use a one quart bottle with the plastic tip. Squeeze it all in, then refill and repeat. A short piece of 1/4 or 3/8" tygon (clear vinyl) hose will allow you to squeeze out the last drop.
Now a days I use a manual suction pump from MAC Tools for about $15. They're also available from most parts stores but often of inferior (leaky!) quality.
In the shop we use a bulk bucket lever type pump on a five gallon pail.
I use non synthetic 75w90 or 80w90 Exxon-Mobil gear oil. Cheap and works good. It gets changed anytime I swim the axles, as soon as I get home from that trip. So every year or so, sometimes twice a year. At that rate, the benefits of synthetic oils don't add up.
The transfer case is running redline synthetic gear oil. The good stuff.
Is that because you're leaving it in there a good while? I'm still researching to make long-term lubricant choices.
Haven't changed it in three years, but I don't drive as much as most people do, about 20k in those three years. For me its prolly gonna be a lifetime fill.
Oh wow. Yeah the economics on primo oil are pretty good at that rate. :)
On a side note - a little more Mud reading has me just about convinced that the condition of the front diff gear oil was grease contamination aka birf juice. That job (front axle rebuild) was already planned, but I guess I'll need to move it up.
