Are you referring to a company or equipment? If latter, what’s the recommended stuff (compressor, tank, blaster, ...)? Thanks.
A company.. it would cost a ton to buy the gear needed...
Pay particular attention to the rear sill, seen in the second picture. It looks like its past starting to blow out and rust away. Usually the bottom of the rear door posts also need to be replaced at this point. Although your lucky Florida doesn't use much salt during the winter. The rear takes a pounding and it's where you need good structural strength. Hook up with @shawnfj40, he knows a lot about cruisers. Pictures of the interior, engine, frame and chassis would help an evaluation. Pull up the floor mats and look real good at the floors, spend some time underneath. I just did a second wheels up restoration on a 78 FJ40LV-KCJA and spent approximately $18K plus about 700-900 hours of my labor working from June to December about 25-30 hours a week.I can't believe my luck. An hour and a half with an agricultural jack and a couple of 4x4's and the body is now dead straight. All the doors close and all line up just right. The roof is trashed, though. It's beyond repair. I want a hard top, so I'll need to find another roof. Amazingly, ALMOST NO RUST! The only rust I can find is the rear sill below the cargo doors. The body will need some serious hammerin' though. The left side took a beating when it rolled. The front fender is too crunched to straighten.
