How Big Is Big?
Hey Team,
I'm getting psyched up to do my front axle resealing job and I'm in the market for a BFH for the job. I have a 2 lb. brass hammer already. Would you suggest I get a 3 lb. sledge, a 4 lb. sledge???
I also need to get a brass drift somewhere.
Thanks
Russell
Someone will chime in and say YES, or D. all of the above. Really, its whatever you have on hand. The brass drift kept me from needing a bunch of different brass hammers. I could whack the brass drift with a heavy ball peen without risking damage.
The best tool for taking the birfs apart is patience. When the cone washers are stuck in there, just take your time, resist the urge to start whaling on them. Same thing for the inner axle seal, and when you take the birfs apart to swap sides (you do plan on swapping sides if not replacing the birfs, right?)
Oh yeah, and a big tarp to park the truck over to catch some of the birf soup splattage.
two lbs is more than plenty.
irrc the "big" hammer i go to when i normally need a bigger hammer is a 24oz. ball peen. i have a two pound mini sledge that i don't think i have ever used.
the usual hammer is a 16 or 18oz ball peen, and it's almost always plenty.
What you've got is plenty imho.
Naturally being a cruiser you will need.......
Your hammer should be fine. The drift can be bought in a big set from TSC. that is all i needed for mine and it was rusted to hell. You will want an impact gun too. They make everything easier. I got an Ingersoll Rand 231C(aluminum body) also from TSC.
I would actually buy a piece of 1/2" steel rod from Lowes or some similar place and cut a piece about a foot long to use as a drift. The steel bar is soft enough. That should be all you really need.
