Hours per Gallon Idleing?
Crescent City, California
Anyone know just how much gas is used in long term idling? I'm thinking of safety enhancing the 80s exhaust so I can run the engine overnight with heater on for sub-zero camping. Any negative wear effects on the engine doing this?
When idling a vehicle for extended periods of time, the combustion chamber never gets really hot and so it is possible to get carbon build-up on the valves and chamber, spark plugs fouling, etc. The catalytic converters also won't get really hot which might cause them to clog/fail.
The other issue with extended idling is overheating but probably not a problem in sub zero camping.
Get a warmer sleeping bag.:grinpimp:
Cheers,
Sean
Buy a small generator, an electric heater, and fab up some way to duct the heat into the vehicle...Oh, and x2 on the warmer sleeping bag (like a bag good to -30 degrees)
Seriously, I don't believe it is recommeded to idle your vehicle for more than 5 maybe 10 minutes, just long enough to warm up the internals of the engine and get the oil to a consistency thinner than sludge...
DON'T DO IT!
That's a good way to get a nice long dirt nap.
I don't think it's possible to make it safe enough to bet your life on.
I must agree this is a very bad idea.
Here are some good ones:
You can get a warmer sleeping bag. If you are too poor/cheep for this get some old blankets and a couple under and a couple over you while in your sleeping bag(works wonders). There are also sleeping bag covers and sleeping bag liners that do the same idea.
Also if you check truck stops or look around online you can find a 12v electric blanket fairly cheep. Just don't kill the battery.
http://www.heatedcarblanket.com/
http://www.electricblanket.net/Comfy+Cruise+Electric+Car+Blanket.html
Another idea is a small electric heater.
http://www.12vheaters.com/
Hope these ideas help.
E
Ever heard of carbon monoxide poisoning ??? How about Death ???
I never seal my 80 when I sleep.
I always crack the windows...plus I wouldn't run it all night, just for a warm up if the cold woke me up.
Some key component to staying warm at night in sub zero temps are:
1. First and foremost is to have a bag rated for the temps you will be sleeping in.
2. This may sound crazy but it works, exercise just prior to going to bed. The increase in your heart rate and other bodily functions will fuel your bodies furnace overnight.
3. Don't go to bed in the clothes that you have been wearing all day thinking they will keep you warmer. The trapped moisture in these clothes will actually make you colder. It is best that you strip (added fun if a female is involved) to let the moisture evaporate from you body. You can then put on a clean set of poly long underwear that will keep you warmer in your bag.
4. To have added heat in the morning inside your truck the electric blanket idea sounds good. Maybe a ceramic style heater? I would be concerned that anything that produces heat draws a lot of power and would drain a battery overnight. If it were me I'd use a small gas powered generator outside of the vehicle to provide electricity for any of the above mentioned heating options. You could also plug in a block heater/battery heater/magnetic oil pan heater as well if you have concerns about the vehicle starting in the morning.
5. If you sleep inside the vehicle at night you should leave several of your windows cracked. If not you will wake up in the morning with a lot of condensation inside your vehicle from your body shedding moisture through the respiration process during the night.
6. Invest in a remote start so you can fire-up the truck and warm it up just prior to getting out of your sleeping bag.
The proper equipment is a must for safe winter overnighting. Some of it is not cheap, but what price do you put on your life. Do not sleep in your vehicle with it running......
Ah, something I know a LOT about.
USMC Veteran who is certified in cold weather survival (-50 with a windchilll of -50) who has seen his skin slough off and watched a doctor cut/snap off dead toes of fellow Marines. Ah...the good life. (sips warm cocoa)
You want to know the secrets of staying alive...well...I'd have to show you that in person, but there are some things you can do to keep you nice and TOASTY in the absolute coldest places on the earth.
Here is my sleeping bag on ebay, not cheap...but you can't beat it, PERIOD.
USMC STANDARD ISSUE SLEEPING BAG
Key notes are that this is a triple layer mummy style bag with snap and zip enclosures. The snaps are so you can extract yourself from this bag in an instant, very handy when you hear a noise that doesn't sound friendly (most often animals like bears, big cats, and racoons). The three piece system works like insulation.
The inner most bag is for cold weather (-30'ish)
The outer bag is for warm weather (zero) combined together they get you to about -40'ish.
Then comes the magic!! The Gore-Tex bivvy cover that can be used with all the components individually or assembled. This is a waterproof/windproof/fartproof enclosure that allowed me to sleep soundly and comfortably with 1 foot of snow on top of me (we don't use tents much in the Marines anymore.)
Now, the secret to surviving in cold temps and sweating in a sleeping bag when it is -50 outside is to sleep....NAKED. Yes, I said NAKED! You want to expose the most amount of body heat to the bag (all the layers retain heat and the goretex keeps it from escaping, but lets the steam out) so the bag can maintain it's efficiency by reflecting your heat bag at you. If you wear too much clothing to bed you keep that heat around your body inside your cloths. If you don't believe me...try this yourself.
Now, here are some tips that you might not have heard (if you are in the military you may have).
  1. Drink plenty of water while in cold temperatures, you won't feel thirsty but you have to drink to stay warm (water is an important catilyst in the glucose exchange)
  2. You need to eat 4 times a day at a minimum when dealing with exposure, your body is working three times harder in the cold climate to keep your temperature up. It needs as many starches and simple sugars as you can throw at it. Trail mix is great for this.
  3. Change your socks at least twice a day if you want your toes to be warm. The sweat cools your feet quickly and should be removed freqently. I would usually keep socks in a pocket so they could dry, then swap with what I am wearing.
  4. Sleep with a beanie on your head, it will be outside the bag and you lose a lot of heat there.
  5. If you get hot in your bag, unzip it slowly until you are comfortable again. Opening the bag and exposing your body to the cold can have bad effects. (especially at -50)
  6. You will want to buy a piece of foam to sleep on. Either an ISOMAT or some other backpackers sleeping mat. Seperating yourself from the ground can raise the temperatures you can survive in greatly.
  7. Keep all your clothes in the bag with you that you plan to wear the following day. This way you can dress in the bag and be WARM when you exit.
  8. Keep your M9 or M16 in the bag with you as you might...erm...nevermind.
I still use my issue bag over some of the more expensive "backpacking" sleeping bags I have purchased. The USMC bag is heavier, but it kicks the snot out of the competition.
Thanks Proven;
Very enjoyable reading.
A couple more tips we use when cold weather backpacking. Eat a light snack before bed. Heat up some water for your Nalgene bottle and sleep throw it in your sleeping bag. And if you don't have or like using a mummy bag, definitely have a beanie.
Don't you guys know about special heaters that use your engine's fuel to generate heat? Go, for example to this site www.webasto.com. I have one of these in my Pathfinder. It is mounted in the engine bay or below the vehicle. You connect it to the fuel line for power source and connect it to the cooling system to heat it. You simply need to turn on the fan and you have heat and a constantly warm engine. There are also heaters only for the cabin. Way better than carbon monoxide :-)
Trucks are for travel. Tents are for sleeping.
Sleep in your truck too much and it will start to stink as your respiration moisture penetrates the capet and seats.
I do winter camping. The above is all very accurate.
Eat lots. Drink more water, less beer.
Get naked and put on clean dry bed clothes. Yeah, its cold and envigorating while you change. You'll be warmer in the end.
I have an old old North Face Bigfoot mummy bag. I bought it new in 1985. Buy quality and you'll never have to buy again. I've been toasty in it down into the -10 range.
If you're in a tent, leave the front & rear windows open about 1/4 way or be ready for the sickest most disgusting snow to be falling on you in the morning as the ice falls on you from the sides of the tent.
Boil your water and fill it back into the bottles wrapped in an insulator (I use my coat) so that you have liquid in the morning.
Never bring any flame source into a tent. Ever. Don't smoke in your sleeping bag or tent.
There are many options for this. A generator OUTSIDE will run a small electric unit. The depot used to sell an oil version that was very small. If you do any heater mods, make sure to get a Low ox sensor, there cheap. I had plans to do alot of stuff and never got cold enough to look farther into the project. You really dont need much to heat the small space if your bundled up
I just use a heavy sleeping bag and sleep in polar Tec stuff.
You can always take a fat chick.:eek:
Boz
see all of the above (especially proven) for good overnight sleeping tips, but the answer to the other original question about fuel consumption is about .15 gal/hr for an "average" car. i read that in the newspaper a few weeks ago so if i'm wrong blame them...
