Hours on Vacc Lines....HELP..
Berthoud Colorado
Website
www.w2m.com
Man,
I have spent hours on the vacc lines on my new RIG.......
Any help would be greatly appreciated........all the direction tags are faded and hard to read.. also the line markings are faded.
My truck is a april 78....
Pics:
Man...
I'm glad mine isn't like that!
Whats the problem, are there leaks??? If so try trimming a small amount from the tubing end to get some "new" hose on the fitting.
Miss-plumbed???? The SOR catalog has an allright diagram of routing of the tubes. If you want better, you should pony-up for the emissions manual available through toyota publishing and probably other sources. I got one for my 75 and it is pretty damn good for troubleshooting each system for propper operation. I recomend it for that mess of tubes for sure!
PMK
What do you need to know? I have a 78 that I bought new, that has all of the smog stuff intact. I also have the emissions manual.
Todd Bull.
Razor,
Meet me in the Fort, we can copy my emissions manual for my 78.
And you can look at it, I re-plumbed...
Also, search LandPimp's post on Toyota vacuum tubing p/n. If I had to do it all over again I would use that instead of NAPA tubing...
It is not that bad!
Also - go to AutoZone home page and tinker around there. They have an amazing set of on-line info on trucks and, yes, detailed vacuum line info and schematics for the 40 series. Even gives you very detailed info on what each component does and it is much better written then the OEM SM.
GL,
AndrewT
Razor - here is the AutoZone web link for all emissions info for your 78 40 - http://www.autozone.com/servlet/UiB..._us/0900823d/80/18/8e/09/0900823d80188e09.jsp
Just follow the links for what system/component you want to work on. Detailed emissions schematics are there also. This site is one of the best info resources I have found on-line for the 40 (besides mud of course :D ). The pics they post are nearly identical to the OEM SM schematics but their description and test methods for each system are much better and more informative.
GL,
AndrewT
man,
you all ROCK......thx poblocruise........I worked it all out from the SOR diagrams...made quite a few changes in the hose placement...
Bodyshop crew had to remove all body parts for body resto and no idea what to put where, they did a great job but a few lines were crossed...
Runs like a champ now...thx to you all...!!
Now I can rest easy on a business trip in winterpark....MTB'ing with non other than Gary Fisher and some dude with the last name of Bontregar..:-)
