horn help
maa
I found this horn in the box of misc parts that came with my fj. It does work.
I cannot make out the markings on the back because of the rust. Can anyone tell me
1. Does this look stock for a 72
2. If so, is it the High or Low Horn
3. Is one of the connectors broken, or is this the second horn in sequence
4. What are elephant horns ?
5. Where were the horns attached.
thank you.
Looks like the one I have on a 76 so I would guess stock. I think you'd have to fire it to know tone. They attach to the radiator support. Mine only has one wire and grounds through the mount so I think the connector is supposed to look like that.
Look at the horn digrams on www.sor.com. Elephant horns have a large housing over the horn body and are physically much larger, and were used on early FJ40s/55s. I"m not sure if you can tell if your horn is 'high' or 'low' tone, but the part number would say for sure.
