Horn Contact
The horn on my recently purchased 76 FJ40 was not working so I decided to chase down the problem. I found that the cause was a broken contact switch at the steering wheel. This is the contact that floats against the steering wheel and completes the ground to activate the horn relay. Does anyone know if I can just order the floating contact switch or is this part of the turn signal assembly? I did do a search and did not see anything specific to the floating switch. Also, I did check a couple of on-line parts suppliers and could not determine if it is part of the assembly, nor did I see any individual listings for the switch.
I have this exact issue (broken horn contact that floats against the steering wheel) and also am having trouble locating a replacement part. Below is a pic of the area w/ the broken contact just sitting in the general area. I can't find any reference to the conatct anywhere. Anyone have any insight on sourcing it? Many thanks....Brian '76 FJ40
I'd like to replace mine too, as somehow it became bent and mangled and was grinding away at the wheel when I turn it. Hopefully with your picture I can bend mine back into shape since there doesn't seem to be an available replacement part.
Can anyone else provide pictures from other angles? I could always sacrifice a feeler gauge and make a new one.
I saw in classifieds last week where @447xpro donated a switch to someone who only needed the stalk. Maybe you can find the thread and ask them for the contact. :meh:
We're in the same boat, but we need all of the guts for the horn assembly at the steering wheel. If anyone sources these parts, please let me know.
Thanks!
All these are NoS units too
Pm me please
Thanks
Thanks!
For a ‘76?????
Saw on a Proffitts cruisers vid they used an FJ60 contact thingy to solve that issue
For reference, it is part #11 on the ‘72-‘84 tab at SOR:
