Horn Blast
MN physically, MI spiritually
Some years ago I remember someone having horn issues, like the thing going off and not being able to shut it off short of pulling a wire. This happened to me last night in a parking lot. Just after starting the beast the horn went off and wouldn't shut off unless I pulled the wires.
Does anyone remember this thread or any useful outcome to fixing the problem?
Thanks in advance for any help.
no advice for fixing the problem but if it happens again you dont need to pull wires, just pinch the horn diaphragm if you need the noise to stop asap...like you live in an HOA and the truck is in your garage and your neighbor is cucking funt.
I had that problem. It ended up being the RS3000 Alarm unit. The PO must have dumped a coke or something when using the cup holder on the side of the drivers seat. The alarm circuit board was green and moldy. I replaced the unit with a $15 Ebay unit and it has been fine.
Maybe a faulty relay.
My 80 acted like that for a while, turns out the relay was bad. It has a aftermarket airhorn set-up though.
