Hood struts failing
Northern VA
I've read that cold weather can affect the hood struts and possibly compromise their reliability.
If the temps are in the 30's, and I'm finding the hood will not stay up now pretty consistently, is this a sign that they're past their functional capability and replacement is a foregone conclusion?
There's nothing like trying to fill up PS reservoir in the dark with a flashlight tucked b/w head and shoulder, while having to keep the hood up with your head.
:bang:
Nice.
Where's that thread where someone mounted an LED to the underside of the hood that would trigger on whenever lifted? That would've been handy.
:hhmm:
Thanks.
Yeah, normally I'd venture to say that where you are it would less apt to get that cold often.
However, after speaking with a co-worker this morning down in Atlanta it appears that they've got colder weather right now than we do in Northern VA.
Go figure.
Have you swapped yours out yet?
well Im in boone nc normally so it gets Pretty cold .... for instance it was 11 this weekend and -4 with the windchill.... brrrrr... no havent replaced them yet I just use my highlift handle to hold the hood up for now because they work so dammn well when its not freezing
.....Which can scar the shaft and accelerate wear on what's left of the seal.
:bang:
Nice.
:hhmm:
Thanks.
Not LED, but easy to do.
Allows you to take the light where needed under the hood as well.
https://forum.ih8mud.com/80-series-tech/176216-underhood-troublelight-pic.html
As concerns the hood struts, they are gas filled and cold temperatures will have some effect on them.
Also, they have a seal in the tube (with a slight amount of oil) that wears over time...allowing the strut to leak.
Just replace them.
Here's what I did.
I just formed some scrap galvanized steel so it fit the outside of the strut body, drilled out the bottom bracket to put in a bolt to attach it with. Then I used an old spring I had laying around to keep it as sort of an automatic prop. This way nothing slides on the strut shaft, thereby no further damage to shaft or seal, and it allows full movement of the strut and closure of the hood.
I know, it's kind of stupid, and not pretty, but it works.:hillbilly: Sorta like me.:meh:
