Homebuilt controller for A442?
Vancouver, WA
I have a '94 FZJ80 that I'm planning on swapping a 4bd1t into and I'm working on transmission options. It looks like most people are opting to use the A440 or buy a compushift controller. From all the reading I've done it sounds like the 93-94s have the transmission control unit separate from the ECU. A few people have talked about fooling the stock TCU to run with the swapped in motor...anyone know if this is possible? Essentially I'm curious to know if I can get my stock TCU to work without the 1fze in place.
Thanks.
Apologies for the old thread dredge.
How did you go with this?
I'm contemplating making my own arduino based transmission controller for my 96 turbo diesel.
No. I heard dieseladapters was working on one and I think some folks looked a mega shift from the people that do megasquirt.
Doing a complete bread board/ECU for shifting is not that easy, I have the first one from DA and it is pretty good and I like how my vehicle shifts, buying a stand alone is just part of the swap you need to know which little components to make the connection/signals to the harness and transmission at this time there are no plug and play that I am aware of for the 343 442 440 trannys . I wish you luck it is a bit of work
Yeah it will be a bit of a task. I'm thinking I will be at it for months and months.
I will contact DieselAdaptors and MegaSquirt and see how much their controllers are before I dive into doing one myself.
Cheers
