Nice link Hoser. Food for thought to say the least.
Interesting, from all points of view. I'm going to have to go under the assumption that any percieved gains by this mod are just that...percieved. The data completely contridicts the seat-o-pants meter reports from everyone who has done this mod (or some variation of it).
I like the added noise of an intake, personally...but not if there aren't any real-world gains to be had. Kinda glad I didn't do this now.
I'm all for the data and what the "sqiggly lines" represent...but...my tires squeeled from a dead stop after the deck plate mod. That was not possible before with my LC, believe me I've tried. The sound is a bit throatier, but that wasn't what I was looking for. I wanted to giddy up when needed and I have that now. If things change the deck plate gets screwed back in and life goes on. Skol.
I'm not saying any one side is wrong, I'm just saying I'm a dummy and don't get how it's possible. We need more data to compare.![]()
LJ- Only added the deckplate. I am surprised that your only perceived gains are tonal in nature. Did you unscrew and remove the plate?
Skol
2000UZJ said:Trying to find a 4WD dyno in ATL.
couple of things.
The other dyno was in 2WD.
Stock resonator
4" deckplate
Was the ECU reset? ( never confirmed)
How many runs? (3 I believe, it was installed for a dyno run then plugged)
So to say the deckplate+straight intake tube is pointless is a bit idiotic really. Yes, there is some good data saying it's worthless, but on other motors and airboxes. The Tundra guys saw a improvement on the same airbox/motor so don't jump to conclusion since this didn't work on a 17 yr olds Honda Civic.
So for those who have had the balls to do this mod ( for me it was curiosity) have said good things about it, so the fawk what it doesn't give you 50hp and a SBC sounding engine. It sounds good, response is nice and crisp and from a dead stop on the on ramp to 85 it does not sound like it struggles. I plan on 9 dyno runs with a few days of driving in-between for the ECU to settle down.
3 runs 100% stock
Drive 3 days
3 runs deck plate and stock resonator
Drive 3 days
3 runs with deckplate and straight intake tube.
couple of things.
Stock resonator
4" deckplate
3 runs 100% stock
Drive 3 days
Drive 3 days
OregonLC said:I think your dyno idea is great and is the final word on the validity of the improvement.
Out of curiosity, did you read Hoser's link to the engineering of the resonator? Soarer - The Intake Resonator
The conclusion they came to was that the factory design was sound and that modifications resulted in decreased performance. Forced air and/or continuous flow benefits from large diameter, however the cyclic pulses of a NA inductions system benefit from a properly tuned induction system. This is no different that the critical need to have a tuned chamber on the exhaust of a dirt bike.
edit: this is probably obvious, but you know this only benefits at wide-open-throttle, right? At any other throttle position, the butterfly is intentionally reducing flow. So unless you're completely mashed down there is no benefit.
One dyno location in Atlanta that can fit a 4WD vehicle the size of the LC. $65for 3 runs...
Jesus.
Who wants to help pay for this experiment?
I'm seriously broke but want to offer my vehicle and time for the mud group.
I was tempted to measure/compare the internal volume differences between our stock resonator and the australian spec resonator (with the cyclonic filter) but didn't want to risk water getting stuck in there.The conclusion they came to was that the factory design was sound and that modifications resulted in decreased performance. Forced air and/or continuous flow benefits from large diameter, however the cyclic pulses of a NA inductions system benefit from a properly tuned induction system.
2000UZJ said:I don't think HP changed, but tue kickdown and the way it accelerates seems smoother. If it makes a line squiggly on a sheet of paper big deal. I felt that it breathes better, it's more responsive and crisper. I know the line is important. I would like to do a few runs with a straight tube intake with no deck plate, and then a few with a deck plate to see if it's the deck plate or intake tube that creates the fuel system shutter.
Doesn't the resonator act as a plenum for quick bursts and immediate throttle response so that the engine will begin to rev quicker?
