I can pull the records(also Al in parts can pull all the parts used) 1st tube seal leaked when under wanrantee, around 30k, I am failry sure they were replaced because there was no leaking untill 60k, don't think even a new wiper seal would have keep the greese in that long. I can't remember if its just been one side thats leaked or both or one or the other.
I will be asking to check the bushing as well.
Yeah I don't know why the tube seals have gone, I suspected the same as you the axle isn't running true.
Heck on my 92 that i have used hard, I have only done the tube seals twice(2nd time becuase I was in there for diff work, figured change it out just because. Heck I have done all my own bif maintence on all my Cruisers......never had a stud loosen up. Been many years sense I have done a 80.
I looking forward to the call from the dealer today.
and even if we get stuck with the bill(and we wont) its alot better than what could have happened........money is just money, I only got one mom
[quote author=IdahoDoug link=board=2;threadid=12951;start=msg119761#msg119761 date=1079061920]
Pimp,
The ever suspicious birf service guy in me wonders if they actually replaced the inner axle seal this last time or ever. If you have an itemized receipt to check for these seals it might be worth it as 20k is WAAAY low for that life, and I know of many front axle seal jobs where they skip this out of ignorance. They think the felts are the source of the leak because that's where the stuff's coming out of. So they replace these and wonder what the little 0 seal in the kit is for (tossing into the trash).
As for the shims, the 40s can be shimmed top and bottom and there's a dealer tool to guide their shim choice, but the 80 is only shimmed on the bottom. My 80 and most I've discussed this with have a shim on both sides (bottom only) that should simply be put back on reassembly. Unfortunately, if a tech loses one or decides he doesn't need to replace it and tosses it there is no way to measure it as this is a factory tool the dealers cannot get (according to a TMS USA buddy a few years ago). I bought a few shims for my repack and did some careful calculations to determine my left inner axle seal wore a bit at the 12 o'clock position and corrected accordingly. I'll know how I did on the next repack (still slight wear at 12 and I'll add another shim, switched seal wear to 6 I'll put in a thinner shim, etc). The right side was dead center wear. If you get a good tech, it would be nice to have him pull it out without destroying it and try to assess where the wear is. Then you can call me (PM me for my phone) and I'll tell you what to tell him as to shimming. It took me a long time to figure this out. He'll not likely have the shims on hand unless he orders them in advance. If the seal was indeed replaced 20k ago, then you must have an axle that's offset quite a bit in the tip of the axle housing and that would also explain the short seal life. Not sure you'll be able to pull all this off in the context of the dealer righting their wrong, etc but I'll help in any way for first right of refusal when your Mom sells....heh.
By the way, I suspect inner axle seal wear and condition of the bronze spindle bushing are directly related.
DougM
[/quote]
