HJ60 Fuel Feed Pump Leak
Charleston, SC
Hey Guys,
Started looking for possible issues but, can't figure it out via the googles or the forum.
I have a slow leak on the fuel feed pump. It seems like its the underside of the unit but, could be the back side against the engine.
Should I just grab new gaskets and rebuild and go from there or is there a common failure point?
Thanks,
Couple photos for help :)
uAC9a1mOx9WO3I-Sxtne98mL29259Gwbf9OdKkhJlN0
Umi6cVCHc1zbplcjKkuEhy01tP6MqT5uUWDyrJpSDJM
You definitely have a leak, but it's hard to tell from where. I would begin by pressure washing the area clean, and then closely monitor things from there. Check the priming pump to see if the plastic knob is tightened down firmly, by hand. These can leak, but usually only while being used or when not snugged up after use.
Thanks! I'll see what I can figure out.
Cheap part to replace , clean the inline filter that is in the incoming fuel line too.
file.php
BOSCH Hand Primer Pump Diesel Fuel Feed Pump # 2447222126
Check maintenance 2h-engine PDF page FU-20
file.php
file.php
small filter:
check inline filter 22529 22529-67010 FILTER, FUEL PUMP. FILTER, FUEL PUMP (08.1980-08.1987) 3B,2H..BJ60,HJ60; (mostly nothing there)
file.php
file.php
file.php
file.php
small filter:
file.php
Thank you! I'll replace and rebuild and update the thread.
