HJ45 in Oz
Rotors and bearings done
RE: Marks engine mount adaptors....Are these supplied at a predetermined length or do they need modifying for a individual vehicle (40 Series)?....And I notice the bolt holes in the adaptor legs & the actual engine mounts are slotted, is this to make fitting the motor initially easier then weld afterwards?
The slots are to make the engine easier to fit, the brackets get supplied in two pieces and then you weld them together based on where you want your engine to sit. They are all the same I believe as the 40 front doesn't really change between chassis.
i can get closeups if you want a better look
