[quote author=Bo87cruiser link=board=2;threadid=5541;start=msg44064#msg44064 date=1064327494]
Thank goodness IdahoDoug:
The harder you put an oil filter on, the harder it is to come off. IdahoDoug's technique is the correct way to install an oil or any kind of filter that employs a rubber gromet/gasket. Once you get these gaskets snug, the heat of the engine will make them even more tighter. I have strained for 45 min before trying to get filters off 18-wheelers just because some knuckle head put too much elbow grease on it.
This is the only way to go.
[/quote]
The worst car I can remember was a GM transverse V6 with a small filter high on the back side of the engine above a crossmember. Hard enough to get to and always on super tight. I distincly remember having to remove them with an air chisel on two seperate occasions.
I am purposly blocking the memory of the Renault LeCar that required the removal of the A/C compressor to remove the oil filter.
Always lube the gasket and always hand tight. I never need to use a wrench on my vehicles.
Time to show your age..
Who remembers which toy came with the "Kung Fu grip"?
This is the only way to go.[/quote]
