High Beams Fixed
These in depth repairs with pictures make Mud Great. Most would have just switched the switch. You dug deeper to find the root cause and it ended up being a free fix.
Nice Work!
I don't have pics but have had two combination switches that the process here didn't work. I had to dig further into the actual high-beam switch than so far in this thread and clean/sand the contacts. One I never got working.. switched it with one off a corolla from the junk yard.
The second I did..
Initially cleaning/sanding the second didn't work.. but what I ended up doing was hooking everything up (with battery, current is needed for this) and flicking the contact itself back and forth, which I assume caused small arcs and got the contacts to clean themselves, as they are supposed to. Going on a couple months now with everything working as it should. The contacts are mounted on a sprung reed that the plunger shown in OP's pics pushes back and forth. I pulled this up with a fingernail repeatedly and let it slap back down.
Great write up and pics. My high beams are working well currently, but things can change quickly as everyone knows. Thanks again for posting this procedure.
