I was having an issue with snoopy this week. The high beams only worked when the combination switch leaver was pulled back in the temporary flash mode. When locked forward for permanent high beam, nothing. Because it worked when flashing I decided to dive into the switch and hope it was a contact issue. Here is what I did and it worked for me. Feel free to chime in or point things out that I missed. I am just happy everything is working.
Step 1: Disconnect battery
Step 2: Remove the covers on both sides of steering wheel. There is a tab on the side closest to the wheel. Just insert a thin flat head and it should pop out... see tab below.
It is the same on the other side.
