High Altitude Jets
Great Thread. Outstanding work Dave. I had my rig tested and they said it was running rich. It wants to die when you first start it unless you give it a lot of choke. I'll check the jets. What's the easiest way to check these as far as "Carb jet checking for dummies" Thanks
If you have the high altitude spare jets in your carb, like I do, I would just switch them out and retest. If you are neither rich nor lean, then you're probably good to go. If you are too lean, or if you don't have the spares in the carb, then I would contact your friendly Toyota Dealer parts department and try something intermediate. Or, if you hate your Toyota Dealer, like I do, because their service department sucks green monkey .....well, you know....then SOR has carb jets, too.
I put the smaller jets in mine and it worked out about perfect. I live at about 7000 and go to 12000 with no real problems. I've never had it below 4500 so don't know what it would be like lower. I'm running a stock F engine. I think you should try it and starte with fresh plugs so you can check them on how it's burning. Just don't get it too lean or you'll toast you engine over time.
We live at 7300'...what size jets are you running? 1974 "F" engine
How did you find a ten year old thread? Having said that, I'd love to know too. I've got a non-US carb and I think they use different jets again due to no pollution kaka.
HA! Look at that, I didn't even....google search :) Anyways...doing more research we found someone who was using 1.80 & 1.14 and it's working fine...that's as far as i have gotten so far!
