HID relay harness mounting location?
Al.
I searched a bit. I couldn't find where people are mounting these. IF ballast can set in the space behind the side marker, in the fender, where is a good spot for the relays?
Thanks for any help
Jerry
as typically happens, I ask a question and then go ahead and do it without advice. The morimoto HD relay harness isn't great for land cruisers. I extended the ground 3 inches. It's all good. Works like a champ.
I have my HD Relay mounted on the driver side of the fan shroud down by the battery. The driver side ballast is mounted in the fender and the passenger ballast is mounted in front of the air box on the inner fender.
I ended up with relay by the airbox. Just made sense with my length of ballast wirs and +12.
Thanks for the info guys.
