HG done- 3 concerns.
Saratoga Lake, NY
Just had my head gasket replaced. Picked it up from the shop. 3 things concerning.
1 air bag light is on. Did a search. Came up with a fuse to look at. Where is this fuse?
2 the shop put napa antifreeze in it. Do I change to Toyota Green?
3 There is a little bit of a misfire. Kinda like the typical misfire. But a little more pronounced. New plugs and wires installed during the HG operation. Throttle body wasn't cleaned.
I put about 300 miles on the truck this weekend pulling a snowmobile trailer and sleds.
Ideas?
all parts from Dan...
For 3 - Fresh intake cracks from removal and reinstall of intake components? Spark plug gap?
It's either Toyota Red or Prestone Green, never the two should mix and a real ggod flushing between. However, I know nothing about the NAPA stuff they put in and it might be equivelant. Do you have more info on it?
Since you had it done at a shop, would do they say? Why don't they fix it?
I'll take it back to the shop tomorrow. Just need a little info. from you guys before I hit the shop door.
Nater please expand???
The intake tube between the filter and the throttle body develops cracks when flexed (such as when it is being removed)
If it was old and brittle there could be hairline cracks letting unmetered (and unfiltered!) air in which causes roughness. Just a though... you should be able to remove the tube and visually verify if they are there or not.
Ok, which filter? Fuel??
No, the air filter. It is the tube that goes over the valve cover and houses the MAF.
Ok, thanks you guys. Per usual good info!!!
Romer, the shop said NAPA antifreese was good for all makes. I'll get it flushed and put red in it.
But....What about the airbag sensor?
You should flush the coolant anyhow after this work - debris gets into the block - sanding grit, etc. Goes for changing the oil after a few hours operation as well.
DougM
PDoyle,
Ditto Romer. If you didn't have these issues going in, why should they be present after?
Very simple, ask them to make it right.
Let us know how it goes.
D
Follow up. The shop reset the code for the airbag sensor. Think it was #31?
All is good... So far...
The mechanic said the battery was low after the HG install, and he cranked the motor to start it and didn't turn over. After a quick charge. Started. He never noticed the airbag light tho... Must be a busy guy....
Changing oil and flushing coolant in a couple days. After the 2 ft of snow hits!
I wish everybody followed up...:o
Low battery can cause an airbag light.
No reason to go back to Toyota Red, unless you suspect he did not flush the red out before adding NAPA green. Some of the new green antifreezes claim to be compatible with silicate and OAT antifreeze. As far as I'm concerned the jury is out on those claims.
I'm one of the few anti-OAT proponents on this board so take my concerns with that grain of salt.
Well, look at your # of posts and look at mine. I can be a good listener.:D
The shop has a power flush system. It is supposed to completely flush the whole system right? Think there is any residue from the HG install that I would need to have flushed out at this point?
Gumby, If Toyota Red were the same OAT as Dexcool I would agree that is was crap,
but it is not. the major offensive ingredient 2-EHA is not present in Toyota Red.
What'd they say about the miss?
we were outside yesterday and it was about 10 degrees when we put the box on it to check the codes. So, I'll get that looked at next week during the flush and oil change. But, it really isn't that bad.
I only hear it at the tail pipe, and it's sporadic.
Landtank mentioned the plug gap, and I'll check the map line too when it's inside the garage.
Note: installed new/rebuilt injectors, plugs, wires, a bunch of little water hoses, and valves were adjusted too.
Dude! You were right! No cracks, just loose clamps. Gotta drive it to check for the miss in the idle, but this should have fixed it.
Grassy ass....
