HG Blown?
:lol:
Just had a buddy get a blown head gasket diagnosis on his exterra. Drove 5 hours one way to check it out for him....ruptured a heater hose at the firewall and was hemhorraging coolant onto his exhaust. Point being, make sure it is in fact a head gasket failure before tearing it apart. I will say that your description is dead on for that diagnosis. You can use a Block Testing Kit from Napa to confirm. I did mine about 2 months ago? It was a pain in the rear. And if took 5 days to do. This did include waiting for unforeseen parts to replace and a disentigrated heater valve. Keep in mind you will find things needing replaced as you get to tearing into it or putting it back together. Mine had been thoroughly molested and put back together pretty poorly by a land cruiser shop that will remain unnamed. I only know this from the PO and receipts that came with the cruiser. Shameful work they performed, utterly shameful. Anyway, that alone cost me a day undoing all of their garbage. So as a former mechanic and shop owner operator, 3 days with all necessary parts and without machining is doable. Average person might be 4-5 parts available no machining. Given your circumstances I wouldn't think machining is necessary as it didn't blow while under load or from overheating and overheating didn't occur. Then again PO overheating could have caused warpage that lead to a failed HG. Just make sure you have a 36" long stainless steel straight edge and angled feeler gauges to check for distortion and warpage. If it checks out then there is no need to machine it. Replace your head bolts now instead of later. Don't bother measuring the. Because length may be correct but as I have learned more than a few times...doesn't mean the head bolt is any good and it can and they do break at or after install.
DVD is good, but between the FSM info given & how well the motor is indexed for head remove, you're good - if you feel you caught this prior to overheating, machine work on the head prob won't be needed. Info in FSM is extremely well written to the point it drops a good 2 bananas off the job IMO.
You prob don't have a leaking radiator, you can check it by filling with plain water to test run once HG work is done - or let the Barr do double duty & catch rad leaks while maybe getting more time out of motor.
Personally since it's summer I like the idea of doing the work now - ice cold wrenches are a real downer to this job.
Really the one place I recall liking to have bought a tool was the Gear Wrench for a heater pipe bolt on head, tight against the firewall - that tip was excellent, that tool made the job a simple deal.
If you can be sure your head bolts are being turned 1st time since motor build, you can re-use once (going off mem of C-Dan advice, may check w/ him if you 'feed his dogs'/ buy parts from him.
Wow, thanks for all of the great advice and suggestions. I am too late to try Bar's and I thinks it is better that I didn't do that. I am down to the head bolts now. The plugs were all squeaky clean almost like they were brand new. I don't know how to tell if the head bolts have been off before. No beater car for me I have to get this fixed and it is going ok. I will order the head bolts today and everything else is ordered and should be here tomorrow. I am going to tackle the head bolts now and see if I can get my neighbor to give me a hand lifting it off. I have not found a machine shop yet so that is my 2nd priority for today. Lastly I think I need a new wiring harness as mine was crispy and had melted and burned through in spots so I need to order one of them too. I took off the water pump and it doesn't spin freely so glad that it is going to get replaced. If I find a machine shop today I might be able to get my neighbor to drive me up and drop it off but I am going to need to take another day or maybe two days of vacation to finish things from the looks of it.
The head bolts OEM cost way too much. Order ARP studs instead. Paradise Racing sells a direct fit kit that works well, it's what I'm using. If you are in a hurry, there are some opel or some other kits you can use that you get get from Summit, search around MUD for part numbers. I don't think paradise stocks the ARP kit, but you could call them to find out. You can measure the bolts per the FSM procedure, but you need a micrometer, the length is not measured, you measure the diameter in the stretch zone to ten-thousandths of an inch. As long as they are in spec and torqued correctly they should not break. The wiring harness runs down the transmission tunnel and hooks up as far back as your rear O2 sensor. Did you pull the harness through the firewall?
Oh yeah. Pics or didn't happen! :flipoff2:
Both @landtank and @Photoman are kinda close to you. Maybe they have a suggestion. Make sure the head is pressure tested. My head had three cracks and required a new head.
I have the video and it has some cool tricks (but not like the Kim K Ray J Tape)
If you have the time send out the injectors.
A Blackstone (blood test) oil analysis is a good way to know if coolant present in oil and tons of other things. It's like $30
Autzone has a leak detector that picks up a head gasket failure and it's free (tool loaner) and easy by sticking in radiator cap.
A egg carton works for labeling small parts in chronological order as you remove them.
Find a friend to help, if nothing else fetch tools and clean up. I use to go solo, but now that I'm married to the man of my dreams we do everything together....In reality my wife never helps, just complains about how much it costs and how long it takes.
Something here does not compute... :rainbow:
Hmm, didn't realize just HOW progressive Ohio has gotten :p
In Cali they don't a LBGT Wheelers Group called "Toy Boys" and they all have roof top tents?
Cali is known as the land of fruits and nuts.
BACK ON TOPIC...Sorry I was being PC.
Hmmm. What happened? We are all in suspense here... It took me 6 weeks to do my HG.
This whole thing seems not to compute.
So my headgasket job was more than I bargained for. I was able to do the majority of the work, but the machine shop was a mess. 6 weeks later I got it back and another week to install. Finished things up then had to contend with some family issues back home. I'm finally back and enjoying the cooler weather.
