hey cdan
CruiserDan...
I need a power steering pump seal kit for my newly purchased 91fj80 and since you are not accepting messages I thought you might see this.
Dont know if you remember me, its been a while since i have posted around here.
btw...what happened to Junk?
Junk sold his 80 and has a 45
Dan is out of the office till August 11th, thats why he is not taking messages. Try calling one of the other guys there and telling them what you need and request the mud discount
Call him at 1-800-432-6668 it will be faster.
BTW- lets not do part orders in Tech, OK
ROFLMAO
Poor Romer! :lol::lol::lol:
let me make it tech really quickly...
the power steering pump in my fj80 is leaking, does anyone know the best way to get it fixed?
sorry Romer, will try to avoid next time!
whole writeups on how to replace it. I even did one, Cdan did one.
You can either rebuild it or buy a new one.
Replace the highpressure hose and return hose.
The High pressure hose is much cheaper from NAPA, but it does not have the mounting bracket but still works.
You could take your old hose to a shop and have it rebuilt.
i am a cheap f&%ker though.
I will try to rebuild first and see how that works.
Romer - thanks for the info on the hoses, i probably would not have replaced them had you not said something
Make sure you use OEM parts on the pump itself, like seals and stuff. My PS pump was rebuilt some time ago by a local mechanic who used generic parts. It's leaking like a sieve. Have to fill it up every week.
Is it leaking from the pump itself or has the "O" ring under the reservoir gone bad?
On a 91 it's almost guaranteed to be leaking from the back of the pump; they pretty much all do eventually. From what I've heard (Jon Held and others), a rebuild on this unit tends to not be a long term solution. Personally, I replaced mine with new OEM at around 200k miles. (After having put up with a leak for, oh, about 100k miles. :lol: :doh:)
Curtis
When does one need to replace/rebuild the PS pump? Mine's slightly leaking not very much though. For the guys who replace/rebuild is it leaking significantly?
See my post just before yours. I let it leak for a loooong time. Only problem with that is it drips onto various rubber hoses, which due to oil+rubber corrosion is not really a good idea. :meh:
I finally replace mine simply because the pump stopped working. The "no more leaking" was just a bonus. :D
Curtis
Curtis
Maybe a dumb question, but I've heard (somewhere) in the past that power steering fluid is extremely flammable. Because of this I've always been pretty freaked if mine has leaked (69 Bronco, 66 Mustang). Is it really not as bad as I've been led to believe?
Power steering fluid may be flammable.
My landcruisers take ATF.
so what is better for the cruiser...atf or power steering fluid?
ATF is factory spec.
-KK
