Heres the plan
Seattle, WA
Ok, I am starting to get tired of my old 3speed with its unsyncro'd first gear and I am hoping to take a road trip in about a year and a half so I have come up with a plan. I want to convert to a 4 speed tranny from a 85-up FJ60. I want that paticular kind so I can bolt it up to a fj62 transfer case. See, I want the keep my cruiser looking as stock as I can. So the plan is to use the vacuum split case to I can keep all the original dash controls for the t-case. There will obviously have to be some modifications to the linkages but I think that it could work. You guys have any opinions on this idea? Ideally I would be able to use the tree shifter with the 4speed to keep everything looking stock, but that is only possible if "someone" would make the adaptor.;)
You can keep your stock case and bolt a 40 series 4 speed to it by changing a gear and adding a spacer in the case. TPI and others make a kit. You can also run any 3-spd or 4-spd 40 series T-case with your original vacuum shift parts as well. Just remove the shifter onthe side of the case and replace it with your OEM parts. The nose cones are the same '63-'80. IIRC the only other change would be a 4 spd bellhousing.
Unless you just want the split case for gearing I don't think I'd go to the expense. I don't know the driveline length of a 4 spd/splitcase but you might have to relocate the mid crossmemeber as well. I ran a 40 series 4 spd and 3 spd case for a while and really liked it. Only swapped it out for an SM420.
Surely "someone" working on that four-on-the-tree adapter has a 4 speed laying around. If not I think Ige has a couple for sell. I'll have to check but I may have the input gear you'll need to keep the original 3 speed. Oh, I'd recommend a T-case saver as well .... a cheap investment since you'll already have it apart.
Just my 2 cents,
Thanks. Well, my main reasons for wanting the transfer case out of the FJ62 was that you can get a better gear set in it. I like the idea of having .92:1 for high and having 2.82:1 for low range. Plus the case is a lot stronger that my 3 speed case. So I could connect my vacuum asembly to any FJ40 case? Is the tcase off of a late FJ40(80-82) the same as a FJ60 of the same vintage? Thanks
Edit, I guess the cases are different, looks like there was a change in 80.
Hey, I appreciate the advice. I never thought that you could put the vacuum assembly on later transfer cases. That gives me many more options.:cheers:
