Thanks for the insights. For a third of the price, I'll give the Zodi extreme a try and pass it along if we don't prefer it.
Great install. For some reason I like it better on the side like you have it. Need to do this sometime, until then maybe I can figure out how to have heated baby wipes.![]()
So do you guys with the heat exchanger find it a hassle to have to start up the rig and get it up to temp?
Finally got around to finishing my Helton install. Found some color coded quick connects at northern Tool that make sure you only hook it up right.
Adapted the shower kit from CruiserOutfitters to be able split and run right from the bumper or from a pre-heated Jerry can. Former for when it is just me and no modesty required (or extended stays with the Shower Hut at the bumper). Latter for when the Shower Hut is away from the vehicle. Added a hose length to get to source water from a Jerry can, Rackmounted water tank or trailer tank.
This project has high WAF. (Wife acceptance factor). It makes really hot water!
Only wish is I could have found some heat rated blue like Kurt had, but wasn't able to source it locally.
Slick!
That turned out very nice, really digging those red/blue connectors. How tough would it be to swap out the blue hose? I could snag some locally and mail it out... didn't realize it was so tough to source. I think I just need to bite the bullet an buy 100' rolls of it, send 10' (should be plenty for most installs) with the kits? It's not the cheapest hose but it's high temp, thick walled and super tidy.
Slick!
Not meant to degrade your color code idea...but since, at least in the USA, hot water is typically the left side/tap and cold water is typically the right side/tap I oriented the input/output couplers for my Helton system the same way: Hot on the left, cold on the right. Otherwise I'd need color coding, or labeling perhaps, like you've done.
The Helton water heater is one of the very few mods that, on my truck, has not needed attention downstream of the install. A great product if hot water is desired in the backcountry...for any reason.
cboyd,
I forgot to ask: What's your plan to keep the bumper fittings clean/from getting packed with mud/dirt?
UV resistant ones are difficult to find.
cboyd, I forgot to ask: What's your plan to keep the bumper fittings clean/from getting packed with mud/dirt? Hmmm...good idea on the portable dog wash station!
Hey Kurt , still haven't mounted the Helton I bought from you a few months back. Can you give me more specifics as to how you mounted yours in the Death Star? One of your colleagues sent me some pics but not an explanation of how you exactly mounted it. Did you drill holes and then have to get back behind the firewall from inside the cab with nuts/washers? Any additional info you could provide would be great. Thanks!Slick!
^ been running these on my female couplers for the past couple of years and they hold up great! Mucho better than the rubber type hydraulic covers that start cracking from UV @ 1 year or less...
