help with slee harness
Reno, NV
Just installed the slee headlight harness upgrade and now when I turn on my low beams both the low and high beams are on (94 LC with Depots). When I turn the high beams on, again both stay on but the high beams get brighter. What did I do wrong here? I thought this install was plug and play (foolproof). You cant accidentally install the 9005 connector into a 9006 either as they have different internal tabs. This is why I hate electrical stuff...any ideas?
I installed mine too long ago to remember, but it's likely something very simple.
You're welcome for that priceless advice. Someone will surely chime in.
So I just removed and re-installed everything and exact same thing. Again, not sure how I am messing this up as the Slee harness simply plugs into the existing harness and headlight connectors. With the low beams on (both high and low are lit), the high beams are not bright at all (probably should see what the voltage to them is). When I turn the high beam switch on, the high beams are significantly brighter.
I don't think there is anything wrong with the slee harness...I think its with my secondary harness that converts the 9005/9006 to H1-H4. It is made by innovative wiring and I know that a lot of people on here who run depots have it too. On the H-4 connector, there is a brown, yellow, and white wire. On the H-1 connector there are 2 white wires (into same plug) and a brown wire. If I pull the white wire on the H-4s, then my headlights function normally (low only on low, both low and high on high). I'm thinking current is traveling from the white on the H-4 and energizing the H-1....might be getting somewhere here!
ahahahahah, ok that info is helpful :flipoff2:
I think that was it! Looks like the innovative harness was designed to fire both filaments on the H-4 bulb. It was ok when running the OEM harness but I'm guessing the way the Slee Harness is wired is not compatible with this setup. By pulling the high beam (white) wire on the H-4s, I have normal function.
Might want to changed the title to *SOLVED*
Now if only I could figure that out.. Theres a "thread tools" tab on my first post but I cant click on the "edit title" option
Don't run that harness on ours if you are not it compatible or you are not able to check the switching as they describe on their site. Their harness is designed for stock oe harness. You could MELT THE WIRES AND CAUSE A FIRE. Just because it plugs in does not mean it is compatible.
The stock oe wiring setup for the headlights switch the ground. The Innovative harness is desgined to work with that.
Our harness uses that switching to turn the relays on but what comes out at the bulb side is 12v through the harness to ground. So in essence we switch 12v and that is not compatible with their harness.
They do have info on their product page that eludes to this.
