Help with handling the load
I blow through my suspension travel all the time even empty. Timbrens at every corner have taken the jolt out of that.
I just checked out their website. Do you have the bumpstops or something else?
Keep in mind that if the rear sits too high when unloaded that takes away caster
Don't order from Timbren direct. They will send you the overload "springs". You need a different part number. Contact Slee or Just differentials. They both offer the soft ones for 100/200. should be able to set you up.
I did it the hard way and started with the overloads. Then contacted Timbren direct for different ones. They were OK to work with but it took a couple weeks of them sending progressively softer versions until I got the squishy ones.
I didn't know that, but it makes sense. Thanks!
