I recently changed the rear Diff oil on my LC for the first time and noticed a small amount of grease in the oil and it took 5 quarts of gear oil to get back to just under the fill bolt. Does this mean my axle seals are bad?
You can - but be prepared for two days. Lots of thorough threads and also a great youtube video:Nice.Is this something that can be done in my driveway with a few tools and some help from youtube?
...or since the OP is asking about the rear axle. If you have Toyota e-lockers, lock it before pulling the axle.
. BUT like Inkpot said, you should be seeing diff fluid leaking out the ends onto your brakes/wheel/tires.I would just leave oh alone and drive it. I used to have a trail rig with the rear diff pointed way up and if had an extra fill plug about 2" above stock. Took a LOT of gear oil because some JC it was out on axle housing . Worked fine and never leaked.
