Help!! Steering lock problem
Guys,
Went to EconoLube to get the PCV valve yanked out.. took a good 2 seconds.. put the new PCV Gromet and PCV Valve in.. got in the truck.. my steering lock doesn't want to unlock.. I keep cranking the key..and it does not want to move at all...even to the ACC state.. and obviously the steering is lock.. I cannot move the key to the clockwise at all.. Thought it was the key and went to LOWE's and got another key made.. well .. same problem.. what do I do.. Econolube gave me a high estimate of $550.. which I don't want to pay.. I can get it towed to my place and work on it if it is simple enough to unlock the steering.. What should I do.. I need help.. Thanks guys.. I'm the same guy whose 80 is eating a quart of oil every 80 miles..
HELP!!
right, try relieving the pressure on the steering wheel and also check that the gear shifter is pushed all the way forward to park.
a QUART of oil every 80 miles?!?!? wow, that is serious. have you figured out the oil thing?
I tugged a lot.. to the point that I even wanted to break it...but since I was parked at Econolube.. They said it was the ignition switch.. replaced it and charged me $290.. sucks.. I have changed the PCV hoses..Intake hose and the PCV valve.. this was suggested by folks here.. I haven't driven it after that.. but the oil light was on when I was driving it home from econolube.. I've driven it 3000 miles and have put at least 6 quarts..its kind of a bummer..since I've been wanting to get an 80 for the longest time.. found this one..immaculate condition inside/out...engine compartment..underneath..was very clean...no smoke..runs strong.. this oil thing is just bs.. I'll chime in more on my original thread..thanks again guys
