Help, Removing @&%$#!& Idiotic Starter Button
Lone Star State
Pulled out some stupid push button start bull**** that was a fire hazard.
I need to know where the "starter connector" goes to so I can reconnect it, and maybe it'll start with the key again. I can't find anything additional in my PDF manual as far as wiring diagram goes.
Hey- If I am understanding you correctly, the starter connector is pulled away from the starter? There is a black clip that goes on top that it just snaps into, it's the only place to insert it. The other end of the wire goes int the harness.
I thought he meant that someone added a starter button on the dash because the ignition switch/ key did not work well? Haven't several folks posted about this?
Re-read the OP. yes you are correct.
Starter connector had wire that went into cabin, which was then tied into some other bull**** in the cabin fuse box. Namely, an ignition switched circuit. Turning the key as normal will not start the vehicle, instead, one turned the key and then pushed a button to start it which closed a circuit from the fuse box to the starter connector (completely retarded). I ripped everything out, which of course means that turning the key does not start the truck (and I have to touch the wire from the starter connector to the positive lead on the battery).
EDIT: I suppose I could redo it with a relay and in dash button, OR just drive it to a car audio place and tell them to install a remote start w/ alarm.
Starter logic is pretty straight forward on these trucks.
Battery/fusible link/ignition switch/neutral start switch/starter solenoid coil.
Hang a meter off the starter connector wire and check for +12 when the key is turned to start. If you're not getting +12, work backwards.
I can't work backwards because the wire from the starter connector was cut (and then spliced about 4 different times, wtf) to add in the button.
Right now I just have the wire that comes out of the starter connector and no idea where it goes, my pdf manual doesn't have the full electrical diagram.
Currently, to start the truck I turn the key and then get out and touch the end of the wire coming off the starter connector to the battery.
Here is the schematic.
Thanks, that should work. Black/W from ignition to park neutral switch on trans, check for voltage. From P/N SW: Pin 5 Black/R goes to ECU (should still be intact) and look for other Black/R wire to reconnect to starter connector.
Getting a viper remote start/keyless and going to redo the push button and install in dash (properly). I think this will be the easiest.
Just need to find Key turned to "ON" 12v sense from ignition (& maybe use P/N Sense -- although I can't see pushing the button when not in P/N so I might not do this part).
12V Key "ON" (fused) -> Button SW -> Relay Trigger.
Relay breaks (fused) + lead from battery to starter, so for the relay:
12V Key'd ON (Switched) -> (86)
12V Batt + -> (30)
Lead from starter wire -> (87)
Body Ground -> Tab/(85)
I would fix it properly and bring it back to stock. The more you have folks hack into your wiring, the less reliable it will be.
Gotta agree with Jon on this. Two reasons, which it may be either, why people go to a button.
Typically, the starter contacts are rebuildable, which is good as that's the most frequent issue encountered. If it was starting reliably before you extracted the rat's nest of wire, then that may be good, either because they were rebuilt or a whole new starter was R&Red in. The button might end up there if people think it's the starter switch and choose the button as a solution
Less common, but still possible, it IS the starter switch itself going bad (sometimes in combination with the starter itself having an issue, given the age of these trucks.) It's BEHIND the keyed cylinder. People will bypass the switch to avoid spending the ~$100 cost of doing it right by installing the button.
A remote start system will cost more than the switch. YMMV
It was relayed to me that the button was added for theft deterrence (originally hidden). I can redo just the button itself properly at essentially no cost, not going back to OEM doesn't bother me so much as the fact that the prior hack job was a fire waiting to happen (as is basically everything else that was wired up previously that I'm redoing). I don't see an issue with reliability other than fixing any problems with whatever else was hacked in adding the button originally, and I will be correcting that. Currently, I do not have any keyless entry unit and the aftermarket unit would be providing that functionality I wanted anyways with the remote start being a part of that.
Digging deeper...
Connector at the P/N Switch does not look adultered, so I'm guessing I should find a black/red wire somewhere BACK in the engine compartment. Can anyone find where the starter connector wire leads to? Can just follow it from the starter to where it goes.
As for going back to OEM, sigh. Probably the least reliable of options. Here's the OEM connector that goes INTO the female connector from the starter. WHY IN GODS NAME WOULD YOU DO THIS TO THE IRREPLACEABLE PART? F&%! YOU!!
How retarded was this guy, tapping into the B/Y which is for trans (and ABS?) and the B/R for the airbag, wtf. There are more of these T's off the ECU (or were), all of which I wrapped with some tape and will re-do with heat shrink tape and a heat gun.
Seriously... wtf?
And heres some wires from the hack job I pulled out... just a bunch of s*** spliced ontop of more s***.
I'm a little lost here. The NSS is located on the side of the transmission housing and has the shift lever linkage running through it. I believe on the later A343 transmissions the connector is on the switch itself. I'm not sure what you're looking at inside the center console.
SNIP
OK, gotcha. Just wanted to be clear about what I think you have going on. If ignition switch no workee, then the button is a common work around. Maybe in this case, it's doing double duty...but what a mess. :crybaby::doh::bucktooth::shifty:
That's off the ignition switch. The Black/W wire should terminate at the P/N switch, from which a Black/Red wire leads to the starter. Thus, turning the key to start doesn't do anything unless in P/N.
The P/N switch isn't cut into, so I need to find where the wire from the starter goes to see if that's where it was cut.
Funny thing: It works. Connection to ECU is probably intact too since the low oil & other indicators come on when I turn to "start." All this bull**** was done for no reason... and that's one way to ruin a perfectly good truck.
True, all too true.
Of course, whether it starts when it gets all back together is still an open question. IIRC, I had plenty of pretty lights, but still no start. Good luck and hope it does for you. If not, I had some thoughts on these matters here: Some Thoughts on Starting System Failure: Ignition Switch & Solenoid
There a link in it to another thread about the starter switch in my post that also leads to some useful places if you get stuck. They discuss the button option, but I didn't want to go there, but might help with backward engineering that backward engineering you have on your hands. As you say, best keep it OEM over a hack job, even a good hack job. But if you can get it cleaned up enough for the remote starter black box to work, that's going to be a major improvement.
