- Thread starter
- #41
I saw an advert on Ebay UK for a Hydrogen Generator but got cold feet after doing some searches on the net and people saying these are scams.
I am looking forwards to your dyno results & being re-educated... if this works it would be awesome.... (especially like the part about 'stick it to big oil')![]()
In reference to the scam part, I'm going to quote myself from a previous part of this thread. IE:
The problem arises ( and this is why so many people are crying "Scam" ) when the ECU senses mileage figures that are greater than what was programmed into it by the factory, IE, it thinks the engine is running too lean, so it compensates by enriching the fuel air mixture. Most people are not aware of this, or if they are, they are unsuccessful in their attempts to compensate for it. When they try an HHO generator, they get good mileage for awhile, then it goes right back to where it was once the ECU compensates. There are crude MAF sensor devices you can plug into the system and screw around with a couple of little knobs forever to try to overcome that, but THAT is a very inelegant solution. The right way to do it is to install a chip that overrides the ECU. There are chip makers out there that specialize in this burgeoning market, but alas, most of THEM are the true scams. There is one and only one company THAT I KNOW OF ( there may be a few more ) out there that is supplying a true microprocessor controlled device to actively re-map the ECU when you have an HHO generator installed. The company is Volo Performance. If you go there, check out their scam page, to check the bad chip companies.
Bottom line is a decent setup like I have will cost about $350.00 and another 90 bucks for the chip. It will pay for itself in about 500 miles.
