Help on power steering pump
Beaverton, Oregon
Hi all,
I just got done rebuilding my power steering pump for my '96 with the parts I got from Cdan (thanks!). Now I got everything back together and installed.
I put some fluid in and I started the car for a few second. (I heard some noise and I killed the engine). Reason was I forgot the bleed the line.
Questions:
1. Would that ruin my pump? :crybaby::crybaby:
I top off the fluid, bleed the line like some post said. (turn the wheel lock to lock with engine off 10x, watch it, and repeat)
Then I started the car again. Sound better, but there's some noise that I didn't have before the install. Check the reservoir, seems like to put too much fluid, so siphon some out to the level.
Check around, no leak, and I test drove it. Everytime I turn the wheel, it makes noise like there's not enough fluid. It didn't make that sound when it was idle and sitting on the jack.
Question:
2. What's wrong with that? Rebuild gone bad? :frown::frown:
Any help or suggestion would be appreciated. I'm thinking to just buy a new pump.
Thanks,
Probably there's still air in the system, takes a while to bleed all the air out. Mine worked crappy and made noises for a few days, and then one day started to work fine.:steer:
Just did this install this morning. I jacked up the front wheels like it says in the FSM and then did lock to lock with engine off then leveled the truck, turned it on and lock to lock. All noise went away in about 10 mins.
Were you guys having leaks or problems with your PS pump before you did this or did you just do it for PM.
I did it because it was slightly leaking but was GROOOOANNNNING.
Plus it gave me an opportunity to upgrade upgrade upgrade and do another HOW TO :grinpimp:
I did lock to lock again with engine off until i don't see any buble.
Turn the engine on and it groans again. Killed the engine open up the reservoir and I got frothy bubble coming up. Do I have air leak or bad rebuilt?
Or I just need to bleed it more? Thanks,
No groaning prior the install, just leaking on the rear seal.
Is there an updated part that Toyota made for the PS system or is it upgraded because all the parts and seals are new? I don't have and leaking or groaning yet fortunately.
Type it up already!!! :flipoff2: I have an old OEM pump and rebuild kit on the workbench as my 1.5 year old aftermarket POS is already leaking. I want to see what crazy stuff you come up with :p
I must admit, your truck and mine seem to be on similar maintenance schedules and it's been very convenient for me :grinpimp: Thanks!
I recently changed my PS fluid and accidentally lost prime at some point. I also went lock to lock a bunch of times but it took a day or two of driving before all the groaning went away.
what about the frothing? did it went away too?
mine overflow through the cap went I turn the engine on.
