Help! New Birfield Doesn't Fit
Anchorage, AK
I ordered a couple of birfields off fleabay and and am finally putting the fj80 back together. Alas, the right side went together with no problem, but the left side, no way! It seems as though the new birf is machined too large a diameter where the stub axle fits through the knuckle spindle bushing.
I am just going to chuck it up in a lathe an machine it down, but i have no idea of the clearance required. Any one have an idea? Should I just machine it to the same diameter as the old birf?
I think I just answered my own question.:rolleyes:
ANy other ideas?
Thanks, Dennis
I've seen a couple of auctions on ebay and I'm wondering who you bought from. World Suspension is selling a kit they claim will work for 91-2004!? It's very confusing.
If the shaft is too big to fit into the spindle, isn't it also too big to fit into the drive flange?
Anyway, who did you buy them from so we can all watch out.
The user ID is 6512cv. The one side was fine, but the second is about 1/2mm too large to fit in the bushing. I sent the seller an email, but I am expecting no helpful response.
No, the size of the axle fits the flange, its just the area that slides in the stub axle bushing that is too large.
The good news is I "think" (I'm in dangerous territory here) I have figured out how to machine the surface to the proper diameter on my 9x20 lathe.
Stay tuned for further fubar.:D
Dennis
I wouldn't say not to buy from that particular seller, just to make sure to check the fit BEFORE you grease and assemble it and to make darn sure you can return it or exchange it before you enter the transaction.
YMMV, Dennis
The Rest of the Story
Well, I took apart the other side to check it against the birf that seemed to be the wrong size. It turns out that the one I am having problems with was not finish machined where it goes through the hub axle bushing. I am thinking quality control is not their strong point.
Hmmmmm.
Now I need to take the birf off the long axle but it won't budge. 3# hammer and brass drift on full tilt swing, no move.
Does anyone have a secret to get it off? Do I need a BIGGER hammer? I liked the zip tie for putting it on, but I am thinking I jinxed myself as it went together with no effort.
Help please!
Thanks, Dennis
Get a piece of pipe longer than the axle that fits over the axle, wad up a couple of shop rags and shove in one end and drop the axle into the other so the birf is touching the pipe, drop the whole thing (with the birf end up) forcefully on something hard, concrete. The axle will drop down the pipe, the shop rags will keep the spline end from getting buggered.
Must be a really tough snap ring in there, The birf itself has just what I would consider the right amount of clearance in the splines of the axle, but the durn thing won't budge, and it wasn't for lack of ahemmmmm.....brute force and ignorance.
I think I am going to take the whole thing to a machine shop that can machine the birf properly without disassembly, if that is possible. I figure if the shop has a lathe with a large spindle bore, maybe they can stick the axle through the bore and chuck up the birf and machine it. I dunno.
Dennis
Have you contacted the vendor about a replacement? I haven't tried to turn a birf, but some of that type stuff is very hard and needs to be ground, the stock finish looks to be ground?
I sent the vendor an email, no response. I will send him another one. I am not going to bad mouth the vendor, but I will not use him again, guaranteed.
I realize the birf is pretty hard, but it appears to be un-machined in the area I described. I doubt it is a ground surface looking at the other one. Given the fact it is not machined makes me think that there is no heat treatment at all.
Dennis
Hmmmmm.
What I did using a similar sized hammer was hit one of the arms then move to the next hit it and worked my way around, repositioning the axle in the vice as needed (I used wood between the axle and vice). These were not full swings maybe 1/4 swing just a solid hit onto the brass drift. About one hit on each of those little arms and I got separation between the pieces, the clip comes out intact, but I did not reuse the clip. Took only a couple of minutes per side. Hope this helps. :)
Tried that trick and no luck. I just took the axle with birf on it to a local machine shop. They said they could do the machining no problem. Cost I dunno, maybe one of those things in life that just gets out of control.
Dennis
For the most part I agree with buying OEM, however, in this case even with the hassles, OEM would be over $1000 more.
I really couldn't justify the cost of the OEM parts.
YMMV, Dennis
Hey Dennis. I here you on that. Same reason I was looking at these guys for myu birfs. Have you contacted them to see if you could get an advance replacement brfore you start cutting on it. Hope all goes well.
