Help needed for lowered 80.
Hai to all, just installed the espelir super low spring on my fdj80 without replacing the old shock, the car was lowered roughly by 2 inches. Great cornering and cruising along the speed way, but there are some problems. The bump stopper in the two front spring actually touches each other. I desperate need some suggestions, ok here goes,
1) Could i trim the bump stopper, so that they do not come in contact? Any other solutions to solve this problem?
2) Would the riude be improve if replace my old shocks?
3) If i intend to keep the lowered setup, what other mod do i need to carry out?
Any suggestions would be greatly appreciated.:flipoff2:
the bumpstops prevent things from getting damaged if the axle is compressed too far. You can remove them but the likely hood of damage is pretty good.
Honestly, you are on your own. This is an off-road forum for the most part and we don't lower our trucks we raise them.
You might contact whoever sold you those springs and get their technical support people on the phone.
You'll have to be careful when trimming the stops. As Landtank mentions, the bump stops prevent things from going to far, so you'll have make sure they can still prevent the axle from contacting the frame. New shocks may also be desirable... sorry not much help.
Do you have the factory e-lockers? If so you will need to remove them and all components. I'll take them off you hands for you. Your truck should be fine after that. It will corner like it's on rails.
First, let me ask you why do you want to lower the 80s?
1. DO NOT trim do anything to the bump stopper! Leave it the way it is, let it contact each other - bottom and top touched.
2. If you want to improve your ride, I suggest to replace your old shocks.
3. Get JDM TRD front and rear sway bars.
I've installed '5 in JDM lowering suspension kit (believe me when it come JDM everything just not cheap $$$$) and reason I lowered the 80's, I don't go off-road just daily commute from work place to another.
And sometimes I need to park the 80's in lower level - underground parking garage.
Well of course there is an advantage and disadvantage lifting and lowering the 80's :flipoff2:
Lifting the 80s- Great you just video cam, take pic watch and help your buddy going expedition, rock crawl :flipoff2:
Lowered 80s- On straight road, for example on the way going to Cruiser Moab you take lead no problemo going over 100mph :D
Here's the pic of my rig - full JDM stuff start from the stainless steel dual cat back exhaust system, taillight guards, etc.. anyway too much to mention it.
Still having a problem wrapping my brain around the words "lowered" and "Land Cruiser" in the same sentence...
To each their own...If I was concerned about lowering so much I would consider a full air suspension if I were you...then you would have the best of both worlds.
I think LX_Treme gave you your best answer. Although most folks off-road here, this forum is not limited in that aspect and many issues and questions you will have will likely be genric.. Feel free to come back with anymore questions, but most folks will simply not know about lowering here.
LX_Tream, I love anytime you post pics. though not the way I'm or most go you have sure put a lot of love into that ride.
I think I'm missing something here. LX told him not to cut his bump stops (so I'm assuming he has full length bump stops ) and his truck is lowered 5 inches.
Brulongman states having problems with them contacting with only 2" lowering?
LX- how did you solve your bump stop problem, you should have a LOT more problems than Bru does.
Don't cut, remove the stops, the axle can contact the oil pan causing it to crack. The stock bump stop to axle spec is; Front 1.42", Rear 4.09" so when lowered it will ride on the stops.
Shocks are to control wheel, suspension travel, if your riding on the stops you have little to no travel and that’s why the ride is harsh. So even the best shocks will do little to no good at improving it. With the straight axle to motor/frame clearance there is no good, easy way to increase the wheel travel, when lowered. This is why most lowered vehicles are IFS, they handle and ride much better when lowered.
My recommendation would be lots of bling!:D
Maybe the OP is offroading with the 2" drop?
Hello, the main reason i have lowered my cruiser is that i that with the original height, it would difficult for my kids and my ageing parents to get on and off the cruiser, so i figured lowering it by 2-3 inches would solve the issue. But it tend to affect the ride comfort as the bump stopper are in contact. As posted by LX_TREME, i think the set of shock in the picture is like rancho either rs5000 or rs9000x. Which shock would be better in term of ride comfort? I have cheched some of the jap web site, they have some replacement bump stopper offered by Elford, by i don't see how that would solve the problem. Again thanks everyone for dropping a line, i appreciated all the help. :D
If step-in is really your only concern, maybe you should contact Jim at Solid Rock Off Road. I bet he could build you something so your family could easily get into your truck without issue. And it would be a lot less expensive than changing your suspension. http://solidrockoff-road.com/
Then you could restore your rig to the suspension it was designed for --
Although I won't be lowering my LC, but all of mine other rides are lowered. However, all but one were done with coilover systems. My SC400 was the last car that I lowered and I bought some Swift Spings and inside the box was a list of cars and how much of the bump stop you should cut to probably take advantage of the lower springs. I don't know if Espelir has a office here for you to contact... Anyway, GL.
