Vehicle is a '91 Hilux / Surf.
When turning tighter corners ( either way) I have a sort of hard binding and unloading sound, it kind of "pops" as you roll the vehicle. Seems to be coming from the RH side ( JDM drivers side )...
I have found that the noise can be produced while the vehicle is stationary as well, turning the wheel back and forth.
I thought CV joints, picked up a set and installed them. Same hard popping sound. Damn!
I then replaced tie rod ends, same sound.
I'm now trying to track down this noise, and think it may be coming from the RH upper "A" arm... the joint where it connects to the long torsion bar the runs kind of down the frame?
Does anyone recall having a similar issue? Or can anyone offer some insight? I've been pissing around with this all day and I'm losing it! hahahahaha thanks so much!
