Help Me...
i HAVE A 79 FJ40.. THE FULE GAUGE AND THE TEMP GAUGE ARE NOT WORKING.. THE AMP GAUGE AND THE OIL GAUGE IS WORKING.. MY TRUCK IS ALL STOCK.. I HAVE TRIED TO FIX THE PROBLEM BUT DO NOT KNOW WHERE TO TURN.. COULD IT BE A GROUDING WIRE??????? I KNOW SOMEONE OUT THERE HAS HAD THIS PROBLEM... BOTHE THE FULE AND TEMP GAUGE BOTH STOP WORKING AT THE SAME TIME... PLEASE HELP ME SOMEONE.... THANKS SPENCER
Maybe it's my eye sight , or my poor hearing but can you guys at least increase your phont to SIZE=7 !!
Thanx :D
FREEDOM--It would appear as though you have "accidently" left the "CAPS" key locked.
Unless you were trying to scream the whole paragraph.
Junk-- I think you woke up our dogs.
Did you let the smoke out? :doh:
It does sound like a ground or fuse to me IF both went out at or around the same time, Im not sure the 2 are on the same fuse or not but it sounds reasonable. :banana:
Lets try and turn this back to help. Freedom, turn your caps off. Thats what the flaming is all about.
Have you taken the instrument cluster out of the dashand made sure everything is connected?
Have you looked to see if the Temp sensor is connected in the engine bay?
I am assuming that you just bought this rig and it has never worked, let me know if thats not true.
When you bought it, did the PO (Previous Owner) say anything about when they stopped working. If the both failed at the same time, I wouldn't think the gauges or sensors, but a common wiring point.
To troubleshoot, you need to define all the facts, then break it down into litlle peices and work those off one by one. You generally start at the snsors or the gauges as a starting point in working through it. I would start at the gauges. We need some more info to help walk you through. Answer the above questions and if the solution does not present itself, then post bach here on how to check at the back of the Instrument cluster.
I would start a new thread when you get to that point to get rid of the "extra commentary". Remember, turn your caps key off.
Good Luck,
Ken
IT SHOULD BE A PROBLEM WITH THE GROUNDING OF YOUR FUEL SENDER, SPENCER. FIND THE TANK SENDER AND SCRATCH A PLACE SHINY ON IT THEN HOLD ONE END OF A PIECE OF WIRE TO THAT PLACE AND THE OTHER END TO A NOTHER GOOD AND SHINY PLACE OR A SCREW THAT GOES THROUGH SHEETMETAL THAT YOU CAN REACH. DO THIS WITH THE KEY ON AND WATCHING THE GAUGES. THEY SHOULD SWING ALL THE WAY UP IF YOU FOUND THE PROBLEM. iF SO, IMPROVE THE SENDER GROUNDING BY CLEANING OR REPLACING IT.
Ah jeez, Ken :)
ken i got the truck and all the gauges worked.. two days later after i got it inspected i drove the truck home and noticed that the gas and temp gauges were not working.. the amp and oil gauge are working... they just stopped working.. i am very handy but don't know what to do..sorry about the caps and thanks for responding to my question... spencer vogel....i have fj40 1979. 2f
yeah, i would just check out your connections on the back of the gauge cluster...
and also see if your fusebox gets hot when the car is one, you might have some extra special resistance caused by rust in there....kept my headlights from workin for 8 months and all it was was a tiny bit of rust on the back side of the box
also, make sure that your fuel and temp are good on the sending side. my temp sending unit (or whatever it's called...) was fine at the connection, but abt 3 inches up the wire was grounding against the firewall
malphrus
Take the two screws off the front of the instrument cluster and the cluster pops off. Feel to see if any connectors are on loose before taking off the speedo cable.
Careful of the back of the cluster. There will be some hot (Voltage) contacts.
Spencer,
The reason that I pointed toward the fuel sender as a possible cause is that in looking at an fj40 schematic NOT of your year that sender was connected to one side of both of your inop gauges but did not appear to share the same connection with the other two gauges. It wasn't a very clear diagram and as I said it wasn't for your year model but it seemed a logical possibility to me.
I TOOK OFF THE screws.. and will not come off the speed cable seams to very tight and getting in the back of the panel is also very hard to disconnect the cable.. all connections look good no rust.. my truck was kept in a barn only 37 thousand miles.. original.. so rust is not a concern but getting off the instrument panel is not easy unless the speed odomiter cable disconnects under the hood.
