- Joined
- Sep 11, 2005
- Threads
- 184
- Messages
- 2,995
- Location
- Ashburn, Va
- Website
- www.landcruiserheaven.com
- Thread starter
- #21
This is the exact same noise I was getting from the power steering gearbox. The check valve in the valve body is rattling back and forth. It also affected oil pressure.
I thought it was a rod bearing but it wasn't.
How is the steering? Stiff?
If you get a stethescope, I bet you will find the noise the loudest on the output pipe from the ps pump.
Thanks for the advice. What did you do to fix it? Replaced the spring??? Havent really moved the steering as i havent driven bit i will check tomorrow.
