Help LX450 won't start
Check Fusible links, any blown?
You are correct, I checked D12 on the ecu no voltage.
Then checked ked the EFI relay, it was good.
Next in line was the EFI, fuse and it was blown.
Damn, that was one of the first things that I checked.
Just happy it's fixed now.
12.3 volts is not enough. Must be 12.5 minimum.
Find your drain from the new stereo install. Isolate circuits fuse by fuse.
Get rid of that heavy gauge wire and get the fusible links back in there or you are risking destroying your wiring harness if not burn down the vehicle.
Will do, it was a temporary check to eliminate possible issues..
