HELP! Last Try!!
Alright, need help on a 92 fj80. It spins but doesnt start.
i have NO spark, NO CEL.
I DO have +12 on B+, Brass Screw.
Brand new EFI main relay ( 2 just in case )
Also when i leave the key in the on position for a while the EFI main relay will start to click constantly.
yea, i saw that already, i also forgot, Coil/Igniter changed, ECU also changed......also apparently toyota only sells fusible links (amp fuses ) no "WIRES"....
pic of my fuesbox...
You're getting NO spark? What about the ignition system (coil, distibutor, cap, wires, rotor)? Why aren't you getting spark? Am I missing something (entirely possible)?
I had the same thing left me on the side of the road towed it home. Ended up being just the rotor. Now I have new plugs wires, etc.....
center button inside the distributor cap still present and not missing?
center button? ill double check that, what does it look like? and my dad says he put on a new dizzy cap and rotor already, also new spark plugs and wires!....im clueless....
How do you know you aren't getting spark? What method did you use to determine this?
You've just diagnosed your problem. You have intermittent contact on the coil side of the EFI relay...hense the clicking sound. Find the bad connection.
The EWD and FSM are invaluable for this.
First thing I would do is make a jumper wire using 2 male spade connectors and jump out the load side of the EFI relay contacts in the fusebox. Turn ignition key to ON and see if the CEL is on. If yes, start truck. If good and no smoke or burning parts under hood, you can function like this for a while...BUT...you must pull the jumper when parked for longer than a day or your battery will be dead. Ask me how I know.
If the jumper does not light the CEL you have another issue, but the clicking relay is a dead giveaway.
You said, "I DO have +12 on B+, Brass Screw."
Are you referring to pin 8 on the check connector when you say B+?
As quoted from my diag page, "Check for +12 on pin 8 (B+) on the CHECK CONNECTOR mounted on the right side of the fire wall. If +12 on pin 8 and still no CEL, then EFI circuit OK and problem is with ECU or related wiring."
You can NOT have +12 on pin 8 of the check connector if the EFI relay is open.
Please re-read my diagnostic page and reconfirm step by step.
YES there is 12 volts at the B+ in the diagnostic box by the passenger side firewall....if its a wiring problem which one should i start at?
Can i get a pic for this....
Guys,
I have exactly the same problem right now with a '93 FZJ 80.
I checked the EFI relay and Fuel Relay with no luck.
I am not good with electrical and had a free tow to AAA. They diagnosed it as the distributor, but wanted $500 plus to fix, and Spectre showed the part as $100 used.
I had it towed to my local Toy dealer and they are saying the ECU based on low elec. read after the ECU. Thus they say I need a new ECU at over $2000!
This probably leads back to me being a dummy and removing an old in car cell phone setup without disconnecting the battery.
Any advice will be appreciated.
A pic for what? A 3" piece of wire with 2 male spade connectors? The idea is to see if you jump the load side of the efi relay (pins 2-4), will the CEL illuminate. That's it. If it doesn't light the CEL then we're looking in the wrong direction.
Your relay is clicking which means the coil (of the EFI relay) is getting intermittant +12 to fire the relay. That +12 comes from the ECU but there are several connections that it must pass through. The other possibility is a bad ground path from the relay coil.
In either case, a good multimeter and EWD will put you on the right path.
While the relay is clicking, have you tried wiggling it in the socket?
If you have a steady +12 on the check connector, then the EFI relay is not clicking. That +12 comes from the load side of the relay.
. []1 []2 .
. . ok heres the efi relay, which ones should i jump? thanks...or ill just tryem all...
. []3 []4 .
. []1 []2 .
. []3 []4 .
To bypass efi relay to get home, which 2 do you jump?
