Help Identifying This Hose???
Feenicks AZ
So im sure i look like the biggest dumbass right now but ive been trying to figure this out for a week now. My 80 is running really bad (Power loss, studdering, shaking, sputtering, 8 Mpg) I originaly thoght my EGR valve was stuck open but upon further inspection i found that the valve was fine. While i was putting everything back together i found a hose coming from this small dark green cylinder with a male fitting broken off inside the tip. Ive been trying to figure out where it goes and what it is for but, the manual, scimatic, and the search bar have been no help so im sure you guys know what it is, and im sure its right in front of my face but its too obvious to see:bang:. Here are some pictures.
its part of the windshield washer set up.. my hoods off now so the one from the top goes to the hood and the one from the side traces back to the washer fluid reservoir
On your air intake hose, right after the air cleaner is your MAF (or AFM or VAF) whichever one it is on the 93-94.
If you have unscrewed the two screws to remove the electrical harness, you have screwed the pooch. That unit regulates many things and it MAY run, but horribly so if you have attempted to remove that harness. It breaks the wires in it when that happens. Too many people have done that and not realized that was what did them in.
Yeah, windshield wiper diverter. Mine was rusted inside out so i got rid of it and hooked the hoses directly together. Now I have front washers, but no rear.
Exactly what i did, couldnt work out why the rears werent working
More info would be good, any codes, is the big hose to the air cleaner good?
While inspecting the big flex hose I found a small Crack on the "flexy" part. So I went to lift it a bit to seal it with ducktape, with almost no force applied the hose just cracked in half and fell into 2 pieces, I might have found my problem. Are there any good no oem hoses or should I just head down to Camelback toyota?
Pretty common at this age. There are generic/aftermarket at a lessor price, but IIRC, only for the later type, some have cut them to work. Camelback is a great option. Can tape it for now, just be careful not to use anything the could be sucked into the motor.
