Help identifying oil feed line
ID, USA
Hello, I have an unknown oil feed line coming off the bottom of the oill filter housing Tee'd off the oil pressure sender. It runs up to a port up on the head. I have not been able to find a similar setup on the forums here and have not heard of valvetrain oiling problems on the 2F. The truck is a 76 FJ40 with what I believe to be the stock 2f. Your thoughts are appreciated.
Looks to be a workaround to this issue:
Appreciate the link, but im still confused why the PO went to all the trouble to put oil pressure directly from the filter to the top end when just capping off the oil gallery would do.
Man if I had answers to half of the nonsense I’ve been fixing over the last year, I’d be done by now. My guess is they wanted the oils to circulate vs plugging. As Mark W posted in the related thread, it’s an awful location for oil pressure.
Remove it all and put an Allen plug in it.
Hello all. Update to this. Here is a video of the valve train. What in the world is going on here?
I’m pretty shocked that the engine still runs. I don’t want to know what the main bearings look like. Ugh
Does any oil come out any of the other rockers?
How long has the engine been run this way?
Yes but not much, though I’ve only looked at idle. Years as far as I know I only purchased it a month ago.
Yes but not much,
So you are getting oil to the rockers. I think I'd remove that oil line, plug the hole in the head with an allen plug, remove the T and put the oil pressure sender where it should be and see if you still get oil to all the rockers.
Perhaps that line was just a PO attempt to "improve" oil supply to the rockers...
further question is why the installer drilled/tapped a SECOND hole into that oil passage. The original hole (the one whose OEM plug comes out and causes problems) is on the rearward facing wall of that boss (can be just seen to the left in your pictures). For some reason the installer drilled this second, larger hole to accept the current fitting.
So when you remove this and plug, you should also make sure the original smaller hole is good, ie pull the OE plug, tap and install an allen plug with locktite red sealant.
I wonder if drilling a second hole was driven simply by the easier angle to drill it coming from the front without the firewall in play (assuming it was done with engine in the truck).
that's wall of shame worthy...
There’s a lot from the PO that is shameworthy. I’ve been to the fastener store about once every 3 days for the past month to replace the just plain Incorrect fasteners the PO had used, including some imperial hardware... shameful. I ended up removing the oil feed line and what do you know, the cheap Chinese aluminum tee snapped off and is seized in the oil filter pedestal, even broke a nice Japanese screw extractor trying to get it out. Suppose I’ll just drill it out and tap it a size larger. What a headache.
What is the factory port plug made of? I seem to have an aluminum plug in place on the cylinder head oil gallery.
Mystery solved. Line is removed and plugged and she gets no oil at all to the top end. Bottom end pressure is good but not a drop to the top. From what I gather the HG is on backwards ( would this cause overheating?) or the cam bearings are misaligned and probably toast.
The 2F HG requires modification to be installed backwards. You'll have to cut the long tab off to clear the water pump. Flip it the other way and it blocks the pushrods from being installed. You could check by running your hand over the back of the block and there should be a small tab of HG sticking out the runs the width of the block. Not saying it's impossible, but geez...
The rifle that was fed by that aux oil line would tee into the vertical rifle feeding the rocker assembly via the tower supply gallery. The fact that any oil was coming out tells you that oil was getting into the rocker tube (which is hollow the whole way down). I vote that you pull the rocker assembly, disassemble it to the component parts, then clean the heck out of all of it. Don't be surprised when you find some serious schmoo and carbon deposits that may need drilling out.
Well I’m thinking that the oil line was my only oil supply and was a bandaid for a much larger oiling issue. I pulled the head bolt that travels down the oil gallery leading to the top end and no oil when cranking. As for the lifters they are shot. #6 lifter bearings are toast and so is the lifter pivot rod. Ever feel like you bought a lemon? 🤣
Dang, sorry to see that... Yeah, that rocker tube isn't useful any longer. At this point it looks like you've got some options to assess. But first off you'll have to tear it far enough to find out what the previous wrencher found that caused them to install that aux line.
I think I’m going to step back and asses my options, frustrating to get an engine tuned up and money spent on parts to find garbage like this. I appreciate everyone’s help on this.
Yes, a poorly installed cam bearing would block the oil path, so would the wrong camshaft. F and 2F used different cam bearing to deliver oil up to the rockers. If he found an earlier camshaft with the wrong bearing drilled, no oil gets upstairs...
