Help identify these sensor...
San Diego
Headed to Toyota now....
There are two sensors right above the oil filter that are seeping oil. Please help identify them... need new gaskets...
Thanks!
I'm pretty sure these are knock sensors. Oil is most likely coming from the valve cover gasket above.
Thanks!
I replaced the valve cover gasket about 3 months ago. Its dry from above and all around the valve cover gasket. The oil looks likes its coming from around the sensor mating interface and moving downward to the block.
Those sensors/senders are for engine coolant temperature. One for the gauge and one for the ECU etc. I'd hope you have no oil leaks coming from them...
Knock sensors are further back towards the firewall.
cheers,
george.
I'm definitely wrong about something here. I'll investigate closely.
I took another photo this morning.
Far right senor is covered in oil.
It could be residual oil left over from old leaky valve cover gasket. I doubt it. If that's the case, I'd expect everything above the sensors to be covered in oil as well. The valve cover gasket has since been replaced 4 months ago.
Not sure what's going on. Whatever it is, it's minor at this moment.
I'll inspect the area more this weekend. After which, I'll clean it up and keep track of where it's coming from.
qX84SYcRCuKru-m1VP0-Q-7KjsaX5CQtvBGfsmNfheTN-E1Z3JPnwW4sfJS_KlvEIm7xLC1DhtyP8o2PqO5Gv3OGAJJKocpdoKbhfPJFrMEKOTM3DemIa03gh56dlMeBlmQiOWaICTGtWRE2PgJfhvxaYYBs_dq9VcZfjqKDLkaowhsn-RdFowEaF8zTchEvt_RYodQoH0fxMBz14BWRu2e5W0trqTfGZsIMcYZnstTy9O6UKvIMhpHfd3RIz71szm-FADlhogLQ2y1c4iFLxCaz1Buv0-62bw5DvpvSIdb0OoKj7quz95HSaNtdb0ZaPl-sX9Mlc5BdX3sDHWZ-ZFELDVZpJ2CRger2CPfsvozVMw1eJ7Iax4IyVEYnxfJniRIi0YovX411jlRZDfbGbFOEGnC4n2Yt3H7g8uehAIjpyxun4aBkpE-Y3GMlDFKTOAidSFRvpbg0N4zKI81_OkmpsYzC7rSHVE0Nx9NKMSwFqe9VqoE0Rl_mJUtUEvaInQsTcUayvySCtrMI1HTIzR1-bNmK-wgcKGMCziREyZIgkRHdLu6yxwwST31hS6UOBYU_cQQhsbHs7hR-DBkYhq5Ai78MaHStbtBAg2t5x0cU7R9C8B_XlCKfk0iikiL6=w969-h1257-no
Off topic but where's that brake booster thread you were working on the other day? The pics that were able to be viewed were good and i'm about to head down that road...;)
Make sure your oil filter is tight and the seal is good. I spent a few hours on the same subject when I bought my cruiser. Come to find out when I changed the oil the O ring on the oil filter had hardened and was leaking oil. I never would have expected that to happen
Clearly leaking from the sensor gasket.
Time to change it out.
Doesn't look like it's easy to get to.
Clean with brake cleaner and recheck in a week/days.
Oil almost always moves top to bottom & front to back.
Distributor o-ring changed?
PCV and grommet replaced?
Be patient, clean, observe....
All you mentioned was changed months back.
The photo I posted earlier today was taken today after I had cleaned the whole area thoroughly weeks ago.
There's the oil pooling and about ready to drip just under the connector body which is also seen in the photo I posted August 29th. From what is being called the coolant sensor for gauge in a photo I posted taken from someone else prior.
Wondering now if that's accurate and really is the coolant temp gauge.
All of the sensors you have shown are in the head and are related to Coolant Temperature. Only one of them (the sensor for the ECM) has an O-ring for a seal. You shouldn't be seeing 'oil' come from any of those sensors regardless.
That is not to say that oil isn't leaking from some other spot and collecting on/around any one of the sensors.
