Help from the oldtimers ...
Oh, Dan know's the part number ... I know Beowulf has spun a few :D
I converted both muffler bearings to the new, improved stainless steel and aluminum bushings. The bearings required too much maintenance and the guys at Jiffy lube just gave me an (even more) puzzled look when I asked them to grease them. The new bushings are permanently lubricated. Kinda like Junk's Mom.
Dan can get you the part numbers but he has to do an off-line order; seems these are JDM only and quite spendy. :frown:
-B-
Can anybody direct me to where in the FAQ if I remember correctly that e9999 did a write up on how to change your windshield wipers?
can't wait till my wiper blades wear out so I can try the amazing new "remove the arms completely" technique again...! :D
Are those the RHD or LHD bearings? Man, the US got screwed on everything!
RHD bearings are installed backwards on a LHD vehicle...........Everybody knows this....:rolleyes:
They are RHD bushings and Dan already answered how to install them on LHD vehicles.
Tucker74 said:
He does still have the record for posting the most technical questions about a truck he didn't actually own until two years later
True, and it is a record that shall forever remain unbroken.
-B-
not you know who, evidently, backpedaling as he may try... :D
I tried to adjust my muffler bearings but I think I torqued them too tight. Now I need a left handed smoke shifter so I can see the road. Does anyone have a spare? I left mine right between the outhouse plunger and the yard of shore line, but it's gone now.
I better go rotate my blinker fluid before everything just falls apart.
ATF is OK for rear blinkers as it deepens the glow of the brake lights. AC compressor oil works better on the front blinkers as it is yellow. I prefer to mix either 50/50 with distilled artesian spring water from a temple in the the mountains of El Salvador, passed twice through a yak. They only sell it in 5ml bottles, but the case break isn't bad.
:D :beer: :flipoff2: i will try bud light next
I prefer plane ole break fluid. :D
I thought I'd save some money by replacing them once, but found it was much easier in the long run to just replace the entire system from the cat back.
good luck with those bearings...I've heard that they're getting more difficult to find.
What is really sad is how many of us where here for the first round of this.
Thank God I have a 3FE with the maintenance free sealed unit bearings in my exhaust.
Dave
Dave
Maybe you do, but that was not a factory option. You must have the rare port installed sealed muffler bearings.
What I wouldn't give to have that!
