Help from the experts..or you
Tulsa, Oklahoma
Its currently 3:52 and I just got back from fishing. My 73 FJ-40 F motor got me there and half way back then decided to start bucking and die. I pulled off the road and it idles fine but as soon as you would drive it for a few seconds it would die again. I messed with the timing on the side of the highway but it didn't help at all. Runs real rough. My buddy and I sprayed carb cleaner in it with no change. Carb is getting a nice stream of gas and was recently rebuilt. I noticed that I couldn't get the idle to increase as much while adjusting the timing. Almost makes me think the coil may be bad. I am going to look things over in the morning becasue I hate when people post on here but havn't done a damn thing to find a problem. So here is what I know oil pressure was fine temp was 180, ran 30 miles to the fishing place and halfway back and then just sputtered and died. Idles fine. Carb is getting gas. Bubble in window is in the middle on the carb. PCV valve rattles fine. Took gas cap off because I have read that on here before. Have not check fuses yet and have not checked the points yet. I was on the highway doing sixty so that may be it. Anyway I would love to wake up in the morning and find my problem solved right here by you guys. Thanks.
You don't want to know what vehicle towed me home.
Sounds like the fuel solenoid, on the carb. I'd check that first, then look at fuel filter and fuel pump.
unhook fuel solenoid with key on and see if it clicks if it does its probably ok i would then go to fuel pump and or filter if they check out blow line back to tank to make sure pickup its clear hope this helps good luck
i would check the pressure that the fuel pump is making. a crappy pump can make a good stream when disconnected from the carb yet fail to make enough pressure to run much past idle.
It runs past idle for like 10 seconds. If you let off you can rev it up but not hold a high rpm for much longer. Also I was mistaken the gas level really low in the window. Could the float be stuck? I have a poly tank that I rinsed out really well when I bought it. I am going to disconnect line to the carb and see how much fule is pumping. I hope there is a little piece of something stuck in that screen. I can see gas going into the throat of the carb though. I messing with it now and I will post some more in a few.
I think the float was stuck. I took the top of the carb off and wiggled the float back and forth a couple of times and put it back down. I saw the bubble get filled up with gas were as before it was really low. I guess that is why it would run for like 15 20 second. But now I have gas leaking into the carb after I shut it off. Its running better but its flooding out when I turn it off. Whats the best way to adjust the float? Or the only way?
how does the gas look in the window?
the float has a tab on it to adjust, it should be the tab that hits the needle and seat.
I dont see a level now so I think it is filled all the way to the top. I think that is why it is leaking into the throat when I turn it off. It runs fine now so some how the float got stuck on my trip last night and caused the motor to run out of gas. That is why it was so low. I thought the bubble was the level on the side of the road.:rolleyes: I guess now all I have to do is adjust the float at least I hope thats all. Tomorrow. Its dark now. Thanks for your help guys.
Check your points, rotor, and distributor cap, that happened to me.
Actually, it's the needle and seat that allow fuel flow into the carb, I'd pull the needle and seat and clean/replace. Your float may be bad or waterlogged as well. Probably the needle is sticking in the seat bore. Not uncommon with bad gas and varnish. The needle rides on the float and acts as a valve to shut the gas off when the float rises.
It sounds like a fuel delivery problem as some others have indicated. Start simple and then work up to more complicated solutions. Most common causes are dirt and rust in the fuel tank, so start by blowing out the fuel line and checking the fuel filter. If these flow fine, then check the fuel pump output. If this is fine, then check the carb needle valve.
Check your oil. If your dumping gas through the carb it will end up in your crank. Mine was about a quart high. 2x on the fuel filter. I had my 74's float sticking every other time I ran it, changed the filter and I've had no problems since.
Kevin
No new advice other than to cut open the old fuel filter after you replace. It'll give you a good idea of whats coming thru your fuel delivery system. A new tank may not solve all problems like if you're still using the stock hard-lines to the pump from the tank (where rust can also form).
I'd also consider adding a secondary fuel filter between the pump and the carb. They're cheap and its good protection.
GL,
AndrewT
I am more than sure that the real problem is the DISTRIBUTOR CONDENSER, just change it , and everithing wil be back to normal. (I recommend changing the points too).
I've got pretty much the same problem twice, first time in a '69 Toyota corona mark II (pickup), and the first time in my 79' FJ40, thats why I'm pretty shure!
Please tell me if I'm wrong!:)
I forgaot, the day that happened to me I was really amazed all that the condenser does!
So here is what I have done so far. I had a vent hose to the filler neck that soomehow got tore open and replaced it (maybe a way to get sand into my poly tank) I took the top off the carb and cleaned out the bowl . Not much if anything in there. Cleaned the little screen in the fuel inlet thing. Nothing really in that either. Replaced fuel filter, a little sand in it. Put a glass filter between fuel pump and carb need some hose clamp so I wont be able to see how that is untill after tomorrow. Cleaned the seating needle in the float bowl. Statrted and runs fine, but now it wants to die when I stop or turn. Window only has a little gas in it. So ifigure somehow gas is not getting into the float bowl. How can I test the fuel pump. I turned it over without the line hooked up to the carb and it shot fuel pretty far.
brian said:
dump that POS aisin, and slap a weber on, for trouble free operation.
[/sarcasm off]
Gee, I had Jim C rebuild my aisin carb 6 years ago and has run perfect since. The weber is the POS, floods out. My aisn pushed 38.5" swampers and now 37" MTRs. Doesn't get up the hill real fast, but has never let me down.
Who still runs points, when pertronix is so much better?
