Help: Driver's door closed with broken latch
Flagstaff, AZ
Yesterday my front driver's side door mechanism broke. Neither handle works; the door is closed. The Starsky & Hutch-style window entries are too high and will get old fast, so...
Is there a way to:
  • open the door without the handles (to better access the panel)? or
  • remove the panel while the door is closed?
I'd prefer the former--doing the repair with the door open rather than closed, but any insights would be much appreciated.
Thanks in advance.
Roll the window down and put a wedge of some sort to see down in the door. Flashlight is required. Shape a coat hanger to reach the mechanism.
The same has happened to my DS rear door, except the window is rolled up and does not function (bad motor). The outer handle pulls up without obstruction but the inner handle is stuck at about 75% pulled out. The lock is stuck in the locked position. I'd wager that one of the linkage clips is causing this but I've been avoiding it for quite some time now. I'll investigate a fix when I pull a different door panel for another repair this weekend.
