HELP asap please!
Arkansas
We left yesterday morning headed to Colorado looking to get into some good snow and made it about 5 hours to Shawnee, OK, where the LC just stopped dead on the interstate. We called a wrecker and he took it to a friend of his who has worked on imports for 30+ years. The mechanic called this morning and said that the distributor looks to have been on fire at one point and needs to be replaced. I am stuck in a motel (with my grumpy wife and two energetic kids :frown:). I cannot look at the vehicle since I don't even know where it was towed to. I'm wondering if anyone is nearby (Oklahoma City, perhaps?) or knows of a place nearby where we could get a distributor rather quickly. The mechanic will be calling around tomorrow, but he probably isn't in a big hurry or feeling the stress like we are.
The mechanic says it's not the distributor cap or the rotor, it's the distributor itself. Anyone have any experience with this? We have a '92 model. Do you know if a later model distributor will work in a '92, just in case a salvage yard has a '95 or another year. Thanks for any help you guys!!
'91 and '92 had 3fe, later models are 1fz.... not compatible.
fuse or fuel filter?
Where can I get a EFI relay, Autozone maybe? And do the 60 lc's use the same distributor as my 3FE?
Thanks
you can get the relay at a dealership for like 15 bucks, common problem, check the fusible links at the battery terminal, could have gotten hot some how.
OK...on fire? I don't think so. I'd like to see pictures.
All 3FE distributors are the same (FJ62 and FJ80).
Ask the mechanic if the CHECK ENGINE light illuminates when the key is turned to the ON position. If not you have an EFI circuit related problem. Please see the link below:
http://gclcny.com/jh/images/Strife/EFIdiag.pdf
Dizzy on fire? Man, what a load.
x4, EFI relay. Maybe $10 at any auto parts store.
good luck, bro! Hope it works out. :)
(watch out for the common "stick it to the stranded traveller" bit...)
Five hours in cold weather..., that's about right for the EFI relay to be suspect.
Does "the mechanic" know and breathe '91/,'92 3FEs?
Jon knows his stuff. Follow Jon's instructions.
Also, as the EFI relay is relatively cheap (compared to a distributor) you should buy several and carry them in the truck.
Once back, you can better tackle the problem without the added stress.
Try to keep a clear head as you work this out, do it step by step. Don't accept the mechanic's verdict without checking it out yourself.
I think the EFI main relay can be interchahged with another relay in the fusebox or in the box behind the drivers side kickpanel. Maybe another 3fe owner can check for you. I would check that before your are charged $$$,$$$ for a speedy repair that wont fix the problem. I have heard of the 3fe relay problems before and a temporary fix was to let it cool for some time and try to start the truck again.
Good Luck
Just wanted to let you know that we FINALLY made it to our destination this afternoon. The mechanic could not find a used distributor so he replaced the cap and roter. The mechanic gave me the old cap and roter and there is definitely an area that is burnt and melted where the roter picks up. I'm not sure why the mechanic thought he needed a new distributor. I'm not too upset with what he charged me.. $150, but it is aggravating that I broke down at 3pm Saturday and didn't get it back until 4pm on Monday. :mad: Thanks for everyone's help!!!
:cheers:
On making your desty - hope you got soem quality snow time! A def. drag to be stranded so long with a dizzy cap. oh well could have been worse - guy behind you could have lost his brakes on a big downhill and used you for slowing down....
