Help!! 91 LC won't start!
my 91 LC won't start, it'll turn over but not start. i've not getting any fire past the coil. i checked my FSM and it said to use a ohmmeter and check the primary coil resistance. it said if the coil tested at anything other than .41 to .5 to replace the coil. well it tested at .7. the secondary coil resistance tested ok. so i got another coil, i tested the new coils primary and it also tested at .7. WTF? the guy at NAPA said its probably the module (i forget what he called it) thing thats mounted under the coil. and that a new one is $250. what else could it be? any way to check the module thing? should i just bend over and take the $250? help guys
It's probably the EFI relay that's in the fuse box under the bonnet.
I believe this repair has been covered here on IH8MUD. If not, there are plenty of FJ80 owners that can assist with the instructions. Check the archives until one of them responds.
-B-
That would be the igniter. Are you sure it is a spark problem and not an EFI problem? 91-92 vehicles have a known EFI circuit issue.
I don't remember if that is the case, IIRC it relates only to fuel delivery. If you do indeed have an ignition issue then your trouble areas are: Coil, Igniter, Signal generator, Power, Wiring. Any one or combination of these couild be an issue. Do you have a FSM?
I do not have a 91-92 FSM handy My 93 has a trouble-shooting tree. It does not detail an igniter test. It DOES state, at the end of all the testing, that if you got this far and you are still not working "TRY ANOTHER IGNITER"
Pretty helpful ::)
I know 1st hand about this problem. Troubleshot my ignition for 3 days before having toyota dealer fix it for $200 labor and $13 in parts. Buy a $12 relay and save yourself some bucks. I've seen instructions somewhere on the web (this site maybe) Seams like an easy fix if you like to mess with wiring.
Greg
91 FJ80
ARB Bull bar, Jacobs Off road ignition, & a Magnaflow exhaust
[quote author=80Diff link=board=2;threadid=12971;start=msg119739#msg119739 date=1079060334]
Greg
91 FJ80
[/quote]
oh crap -- this is something to look forward to -- :(
Eric,
The EFI relay is a known issue with the 91-92 FJ80s and it's not a big deal. The work-around is to buy a heavier EFI relay and there are some good posts that give aftermarket part numbers for relays that are "more robust" than the OEM relay.
IIRC, the root cause is that the wiring to that portion of the fuse box is too small. The permanent and recommend "fix" is to replace with heavier wire; then you can use the OEM relay. Many 3FE owners carry a couple of spare EFI relays just in case.
This is fairly well documented in the archives... if not here on IH8MUD then search Keep's SOR archives. (Where is he anyway?)
-B-
The issue is not the relay, the wire gauge to the relay is what needs to be addressed. I have some old notes at work that I can review tomorrow.
IIRC, there is a reference on 80'scool as well.
If it is the relay you should be able to bypass it momentarely to check for spark. Of course it would be safer to try the $12 relay then immediately do any wiring upgrades/repairs so you don't burn your Cruiser.
[quote author=cruiserdan link=board=2;threadid=12971;start=msg119806#msg119806 date=1079064953]
[/quote]
I would appreciate this tons, C-Dan -- I'll start with your response -- you can throw the cheapie stuff in my latest order -- :)
[quote author=landtank link=board=2;threadid=12971;start=msg119903#msg119903 date=1079099196]
Eric this is really quite simple of a change. The suppliy wire to the relay needs to be increased. This is done by opening up the fuse box under the hood and swapping it out. Then plug in a new relay.
[/quote]
cool rick -- seems simple now --
e
I found my old notes:
There is a 12 gauge wire, red with a yellow tracer that goes from the EFI fuse to the EFI relay. That needs to be changed to 10 gauge. Then there is a 12 gauge wire, yellow with a red tracer that goes from the EFI relay to EB1. That also needs to be changed to 10 gauge. It is a good idea to replace the EFI relay at the same time (90987-02004-83).
:cheers: D-
Make sure to see if the wires have been upgraded. If not, you will eventually have the same problem.
